I've recently restored a Zenith 5-S-127 that receives beautifully, except that there is some sort of parasitic oscillation going on. It whistles, squeals and motorboats LOUDLY on the broadcastand band, though it is present to some extent on the shortwave bands as well. The problem mostly goes away when I touch the antenna lead. Adjusting the wave trap cap makes matters worse. Any suggestions?
Thanks in advance,
Larry
I guess you recapped the set, right? And tube shields are in place?
The wavetrap was for blocking radio signals that were close to the IF. It's no longer required, and you should be able to short across it.
You could try pulling tubes, one at a time, starting at the front end, to see if you can localize where the oscillation is originating. Don't pull the rectifier.
I'm suspecting the RF section ahead of the first detector. Go over that with a fine-toothed comb.
:Hello all,
:I've recently restored a Zenith 5-S-127 that receives beautifully, except that there is some sort of parasitic oscillation going on. It whistles, squeals and motorboats LOUDLY on the broadcastand band, though it is present to some extent on the shortwave bands as well. The problem mostly goes away when I touch the antenna lead. Adjusting the wave trap cap makes matters worse. Any suggestions?
:Thanks in advance,
:Larry
Yes, I've totally recapped and aligned the set. All tubes in the set are shielded. I'lhappens. Thanks!
-Larry
:Hi, Larry. Here's the schematic: http://www.nostalgiaair.org/PagesByModel/888/M0024888.pdf
:I guess you recapped the set, right? And tube shields are in place?
:The wavetrap was for blocking radio signals that were close to the IF. It's no longer required, and you should be able to short across it.
:You could try pulling tubes, one at a time, starting at the front end, to see if you can localize where the oscillation is originating. Don't pull the rectifier.
:I'm suspecting the RF section ahea
::Hello all,
::I've recently restored a Zenith 5-S-127 that receives beautifully, except that there is some sort of parasitic oscillation going on. It whistles, squeals and motorboats LOUDLY on the broadcastand band, though it is present to some extent on the shortwave bands as well. The problem mostly goes away when I touch the antenna lead. Adjusting the wave trap cap makes matters worse. Any suggestions?
::Thanks in advance,
::Larry
Let me know how you do!
Best Regards,
Bill G.
All the Best,
Bill G.
Radios howl especially when the antenna lead is brought near any of the other circuitry. Shield the wiring inside of the set, especially if it comes near plate leads.
All spring shields should be connected to the chassis.
All the Best,
Bill
