Best Regards,
Bill Grimm
Is the audio section operating? Touch center terminal on your volume control, there should be hum.
http://www.nostalgiaair.org/PagesByModel/568/M0025568.pdf
Voltage on pin #1 of the 35C5 is dependent on tube emission. Anything around 6 volts is ok.
Your FM oscillator isn't operating. This can be a bad 12AT7 even if it tests ok.
Don't think solder had anything to do with the problem unless it was acid core? Acid core is conductive & corrosive.
Difference in plate reading is due to line voltage and tube emission, not a problem. Be sure screen voltages are also positive.
:Hi All,
: I hope you can help me with this one. I have been fixing old radios since I was a kid and never got one this bad before.
: Zenith H723Z2 is an AM FM form the 50's. A schematic is on this site. When I got it I found that the filament dropping resistor was open and that one or two of the tubes had heater to cathode shorts. Easy fix. I recapped it, too, plugged it in and WOW! It played great. Sendsitiviy, selectivity, and tone quality were so good, it made me want to recall all the other Zenith 723 and 724's I have done.
: For about a week I played it on the work bench to make sure the repairs were good. I even heard Fibber McGee and Molley on it. After the week it still played fantiastically. Then the socket under the 35C5 exploded. It took off pin 4 and cracked the bulb. I replaced the socket and tube and the radio again played well. Just after I put it in its case I played it, it played for 15 minutes and then went silent.
: I turns out that the socket under the second IF tube had a short in it, too. I then came to the conclusion that I had some how gotten hold of bad solder, perhaps 'No Clean' solder. From then on I did repairs using solder from Radio Shack and got cleaner for No clean solder. I sprayed this cleaner on this radio and another that I was doing at the same time. That fixed the other radio, not this one.
: I also found a problem in the dual frequency IF, the 10.7 coil measure 4.7 ohm, but the schematic says it should be 1.5 ohm. I replaced that, too.
: Presently the radio is dead on both bands, except that I get a tiny bit of audio on strong AM signals. When I change R15 to 47K I can get reasonably good AM sometimes.
: The voltages seem OK, except that on the IFs the plate and screens which should be 90 volts are around 97. Pin 1 of the new 35C5 can be as high as 6 volts (but R29 checks), and the rest of the voltages on the tube are OK. I rechecked this socket for shorts and it is OK. Also Pin 7 of the 12AT7 should be around -5 volts on FM but is around -0.5 volts.
: Any ideas? I am ready th throw this one in the trash tubes speaker and all.
:Best Regards,
:Bill Grimm
Hi Thomas,
Your comments are good ones. Those IF screws are seductive, "turn me! turn me!" they seem to say. Happily I did not turn them. The problem was a bad connection between tube and socket.
The high impedance on that IF transformer I suspected was a bad solder joint. It is hard to immagine what in the coil would cause impedance to climb and not open. That IF had been rebuilt because there was a leak across the wafer, so it did need readjustment.
I only adjust an IF if I rebuilt it or if it looks like someone has been messing with the IFs, which can sometimes be a hard judgement.
Thank you for helping and reading my long tale of woe.
Bill Grimm
Hi Norm,
Your line, "Your FM oscillator isn't operating. This can be a bad 12AT7 even if it tests ok," was like a dope slap. The local oscillator is kind of important!
You came just slightly high of a bulls eye. I had tried another 12AT7 there with no luck. I didn't mention it because my long tale of woe was already long enough I had to edit somenting. I wondered if I may have had two bad 12AT7's. I took one from an operating radio, the one I wrote about the bad speaker earlier this month. The radio started working. I then tried the old 12AT7 and it again did not work. I found however that if I pulled that 12AT7 half way out of its socket, then it, too, worked! That Is why I said your were a little high of a bulls eye, but still scored big!
The radio chassis plays well. Red Skelton tonight at 7!
I will be happy to return the favor sometime, but you are good. I may not have a chance.
Thank you,
Bill Grimm
Sometimes an oscillator will start running if it's kick-stated, e.g., turn the radio off then on again. Maybe pulling the tube out a little from the socket gave it a kick? But once a weak tube is kick-started, it will usually poop out after a while. Anyway, that's been my experience.
Just for grins, check the various components in the oscillator ckt - see if a resistor or cap has drifted in value such that only a primo tube will run. Also look for any suspicious-looking solder joints.
: You came just slightly high of a bulls eye. I had tried another 12AT7 there with no luck. I didn't mention it because my long tale of woe was already long enough I had to edit somenting. I wondered if I may have had two bad 12AT7's. I took one from an operating radio, the one I wrote about the bad speaker earlier this month. The radio started working. I then tried the old 12AT7 and it again did not work. I found however that if I pulled that 12AT7 half way out of its socket, then it, too, worked! That Is why I said your were a little high of a bulls eye, but still scored big!
: The radio chassis plays well. Red Skelton tonight at 7!
: I will be happy to return the favor sometime, but you are good. I may not have a chance.
:Thank you,
:Bill Grimm
Hi Doug,
The grid resistor should be 10K, but reads 9K. I considered that close enough. Now I wonder.
Bill
Old carbon-composition resistors seem to most often increase in value. But, whatever.
:Hi Doug,
: The grid resistor should be 10K, but reads 9K. I considered that close enough. Now I wonder.
:Bill
Hi All,
I still have a problem. It seems that now the local oscillator is intermittant. Even with the 12AT7 tube that always works in the other radio and with the original 12AT7 half in the socket, the oscillator seems to start only sometimes.
Red Skelton was a no show last night on it. The oscillator only started after he was off.
I plan on replacing the low resistance 10K ohm resistor, but also plan on looking elsewhere in the oscillator circuit, as it is only down 1K to 9K. I have tested the 50 pF capacitor and it is good.
Best Regards,
Bill Grimm
Bill,
Have you checked the pins in the socket for a broken one. Some years ago, working on tube communications equipment, on a few rare occasions I found a pin in the socket was broken. This was a plastic molded socket. The fix was to replace the broken pin. On some other occasions I have found a pin in the socket corroded and had to be replaced.
All the Best,
Bill
Hi All,
I replaced the 10K bias resistor on the oscillator, it was 9K and should have been 10K. I also replaced the cathode resistor on the mixer side of the 12AT7. It is supposed to be 2.2k but read 3K, well out of spec. I also checked the capacitors and they seemed fine, except for C10 which doens't make sense. I will get back to that.
After the replacement, no oscillation, dead. It doesn't seem to even be intermittant anymore.
Voltages on the 12AT7 are:
pin 1 97.5 volts
pin 2 0
pin 3 1.73 volts
pin 6 101.3 volts
pin 7 -0.6 volts (switch is in FM position)
pin 8 0
I can get a little audio on AM on some strong frequencies, but nothing that can be listened to.
C10 on the schematic is an enigma. The schematic says it is 0.68mmf. That can't be 0.68pf. Two wires in close proximity will have more capacitance than that. Since it is in the middle of everything I tested it on the bridge. It seems to read around 18pf, with no leakage.
The last thing I did was pull the 12AT7 and place it in a working H724Z1. That radio played fine.
Any ideas? I am still at wits end.
All the Best,
Bill Grimm
Thank you for all the help.
Best Regards,
Bill G.
Any thoughts would be appreciated.
Best Regards,
Bill Grimm
Best Regards,
Bill
Hi Thomas,
I tried a little experiment. I drilled a hole in the discriminator IF can and sprayed tuner tonic in it. I now get the null on the A9 tuning, but no peak on A8. Sound is still weak and distorted.
It looks like you assessment is correct. I seem to have lost connection to the capacitor on the primary of the discriminator. I tried an exterior 15pF in place of it, but there wasn't a change. I may try a 33 pF this weekend.
Even if that works I am reluctant to solder in a capacitor, tune it and call it done, since the old capacitor could reconnect itself at any time.
By the way the local oscillator not opertaing turned out to be a red herring. I made the same check on a working radio and got the same voltage. It seems my meter loads the circuit.
Best Regards,
Bill
Hi Thomas,
I rebuilt the discriminator IF. As you know this is quite tedious. When I went to tune up the discriminator, it tuned like a dream. The primary has a good peak and the secondary has a distinctive null. Perfect!
The radio still doesn't work.
The discriminator was definitely bad of course, but there is seomthing else going on. Further troubleshooting shows that all the plate votages are low, 75 volts, should be 90 volts. Also, when trying to check the tuning of the other two IFs I found that one has a very nice peak even when the signal genertator is turned off!
The term 'parts radio' has never sounded so good, but I had this set playing well in June and it just faded out. Also, I have been telling people that I can get a tin can full of corroded wire to play as a radio. It ain't bragging if I can do it. This thing certainly rates as a tin can full of corroded wire.
Have you ever seen such a misbehaving IF, peaks with the signal generator off?
All the Best,
Bill
By the way, for rebuilding IF cans on this kind of Zenith radio I have found the ideal insulator. They are available from Digi-Key, part numbers BER173-ND or MER105-ND. Either will work.
Best Regards,
Bill Grimm
