I've re-capped this radio and have found that the radio generates pops and static while changing stations. Its picks up a lot of stations but the static makes the sound of the station dirty. The tubes have all been replaced. The volume works fine.
Any ideas?
Greg
Have you cleaned the tuning caps?
:Hi,
:I've re-capped this radio and have found that the radio generates pops and static while changing stations. Its picks up a lot of stations but the static makes the sound of the station dirty. The tubes have all been replaced. The volume works fine.
:Any ideas?
:Thanks
:Greg
I did clean the tuning capacitor using Electronic autoparts spray cleaner. I made sure none of the fins touched through the entire rotation.
Greg
:Hi, Greg, here's the schematic: http://www.nostalgiaair.org/PagesByModel/863/M0002863.pdf
:Have you cleaned the tuning caps?
::Hi,
::I've re-capped this radio and have found that the radio generates pops and static while changing stations. Its picks up a lot of stations but the static makes the sound of the station dirty. The tubes have all been replaced. The volume works fine.
::Any ideas?
::Thanks
::Greg
