That cap you noticed may be leaky? In your tester there may be a resistor across the lamp to reduce sensitivity. The resistor could have gone higher in value?
The actual value of the cap isn't critical. A larger cap will light the neon bulb brighter when you have a short. If the short light lights even without a tube in the socket you have leakage between tester pins. Are you in a very high humidity area?
I have a Hickok 800k and I'm having a problem with the shorts test. It seems that at times the shorts lamp will light on any tube I test, on all the switch positions, even on new tubes. Sometimes I'll test a tube and it will light up the lamp in all the switch positions. I'll retest the next day and it won't have any shorts!
: I was looking at the capacitor that connects to the shorts lamp. It is a .05uf, but it seems that the schematic calls for a 1uf capacitor. Could this be my problem?
: Should the shorts lamp light up if I don't have a tube in a socket?
: Any help would be appreciated.
: Hi John
: That cap you noticed may be leaky? In your tester there may be a resistor across the lamp to reduce sensitivity. The resistor could have gone higher in value?
: The actual value of the cap isn't critical. A larger cap will light the neon bulb brighter when you have a short. If the short light lights even without a tube in the socket you have leakage between tester pins. Are you in a very high humidity area?
: Norm
: I have a Hickok 800k and I'm having a problem with the shorts test. It seems that at times the shorts lamp will light on any tube I test, on all the switch positions, even on new tubes. Sometimes I'll test a tube and it will light up the lamp in all the switch positions. I'll retest the next day and it won't have any shorts!
: : I was looking at the capacitor that connects to the shorts lamp. It is a .05uf, but it seems that the schematic calls for a 1uf capacitor. Could this be my problem?
: : Should the shorts lamp light up if I don't have a tube in a socket?
: : Any help would be appreciated.
I would first inspect the components around the neon lamp and other places in the tester. Be sure the area is clean and dry. It doesn't take much moisture/leakage for a neon lamp to light.
: Hi Norm,
: I just received the tester a couple weeks ago. I will try to open it up and let it air out for a few days. The plywood box may be holding humidity. When I turn the tester on, it may warm up and cause a humid condition. I'll also check the capacitor and the resistor. Would it be a good idea to spray the sockets with Deoxit?
: Thanks, John
: : Hi John
: : That cap you noticed may be leaky? In your tester there may be a resistor across the lamp to reduce sensitivity. The resistor could have gone higher in value?
: : The actual value of the cap isn't critical. A larger cap will light the neon bulb brighter when you have a short. If the short light lights even without a tube in the socket you have leakage between tester pins. Are you in a very high humidity area?
: : Norm
: : I have a Hickok 800k and I'm having a problem with the shorts test. It seems that at times the shorts lamp will light on any tube I test, on all the switch positions, even on new tubes. Sometimes I'll test a tube and it will light up the lamp in all the switch positions. I'll retest the next day and it won't have any shorts!
: : : I was looking at the capacitor that connects to the shorts lamp. It is a .05uf, but it seems that the schematic calls for a 1uf capacitor. Could this be my problem?
: : : Should the shorts lamp light up if I don't have a tube in a socket?
: : : Any help would be appreciated.
