RCA 16T2
8/8/2006 3:33:43 PMMarv Nuce
Just downloaded a copy of Riders for this set and the parts list is mostly unreadable as is a lot of the smaller print on the schematic. I've tried enlarging with Adobe Photo and other apps, but it all comes out blurred even worse. Any suggestions?
8/8/2006 6:37:06 PMrickd
:Just downloaded a copy of Riders for this set and the parts list is mostly unreadable as is a lot of the smaller print on the schematic. I've tried enlarging with Adobe Photo and other apps, but it all comes out blurred even worse. Any suggestions?
:marv
Marv, Just looked at my copy from the CD and for the most part, it can be made out. Speaker field impedence is a little fuzzy, etc. Got some specific problem areas? Lemme know and I'll see what I can do.
Regards, Rick
8/8/2006 8:36:09 PMMarv Nuce
Rick,
Thanks. Its on the back burner, but getting all my ducks in line before I open it up. I'll probably start next week by doing a detailed visual for anything obvious. I'm restoring it for a friend, but don't have anything on it's history. The one thing I noticed was a tapped volume control, and looked at the parts list to assure it wasn't a graphite pot, but it's description was very limited.
::Just downloaded a copy of Riders for this set and the parts list is mostly unreadable as is a lot of the smaller print on the schematic. I've tried enlarging with Adobe Photo and other apps, but it all comes out blurred even worse. Any suggestions?
::marv
:Marv, Just looked at my copy from the CD and for the most part, it can be made out. Speaker field impedence is a little fuzzy, etc. Got some specific problem areas? Lemme know and I'll see what I can do.
:Regards, Rick
8/9/2006 2:05:04 AMThomas Dermody
Seems to come out clearly here. I can type up the parts list if you wish. By the way, I have the chassis from a V-170, which is similar to the 16T2. It uses the same antenna. Would you be able to give dimensions and turn counts? I have to make one from scratch because mine is missing. Working on a radio project kit.
8/9/2006 12:34:27 PMMarv Nuce
Thomas,
Yes I'll remove the antenna panel and get a good close up from its backside, and also count the turns as well. It appears to be unique in it's design. The std loop is obvious, but another round coil (approx 3 inches dia)of many turns is also attached, and may be for the SW bands only. I'll send the .jpgs to your email. A clear typed parts list would be very helpful, and thank you for the effort.
:Seems to come out clearly here. I can type up the parts list if you wish. By the way, I have the chassis from a V-170, which is similar to the 16T2. It uses the same antenna. Would you be able to give dimensions and turn counts? I have to make one from scratch because mine is missing. Working on a radio project kit.
:Thomas
8/9/2006 11:50:27 PMThomas Dermody
I printed it out as a reminder. I'm going to sleep now. I will type it up to-morrow.
8/10/2006 12:23:38 AMMarv Nuce
Thanks Thomas
:I printed it out as a reminder. I'm going to sleep now. I will type it up to-morrow.
:T.
8/11/2006 12:08:39 AMThomas Dermody
Ok. I stop here for now. I'll continue with the speaker information later. I am cross-eyed. Just wondering...what do you need the parts list for? The values are printed in the schematic. At any rate, here's the first part. I will type more to-morrow.
34785 Board--"Antenna-Ground" board
35857 Capacitor--Mica trimmer--1 section of 3-30 mmfd. and 1 second of 6-80 mmfd.
35867 Capacitor--Mica trimmer comprising 2 sections of 9-60? mmfd.
35869 Capacitor--Mica trimmer comprising 1 sectioin of 10-160 mmfd., 2 sections of
25-250 mmfd., 1 section of 50-400 mmfd., and 1 section of 100-540 mmfd. (Models 16T3 and 16K)
34699 Capacitor--100 mmfd., mica
12720 Capacitor--100 mmfd., moulded
34700 Capacitor--120 mmfd.
13003 Capacitor--180 mmfd.
12952 Capacitor--330 mmfd.
35877 Capacitor--720 mmfd.
13885 Capacitor--5,600 mmfd.
30803, or perhaps 30303? Capacitor--.0035 mfd (16T2 and 16T3)
33640 Capacitor--.005 mfd.
6140 Capacitor--.007 mfd.
4937 Capacitor--.01 mfd.
32787 Capacitor--.05 mfd.
4080? Capacitor--0.2 mfd.
35858? Capacitor--Electrolytic, comprising 2 sections of 10 mfd., 450 volts, and one section of 20 mfd., 25 volts
35876 Coil--Coil and resistor assembly [R16 and L2 (L4 in 16T2)]
36874? or 35874? Condenser--variable tuning condenser
35801 Control--Tone control--(Models 16T3 and 16T2)
35935 Control--Tone control--(model 16K)
35859 Control--Volume control and power switch
32834 (or 32534?) Cord--Drive cord
35871 Core--Adjusting core and stud for oscillator coils--(Models 16T3 and 16K)
35785 or 8? Core--Core and stud for oscillator coil
35870 Indicator--Station selector indicator
35856 or 656? Loop--Antenna loop winding
35855 Loop--Antenna loop complete
35936 Plate--Dial back plate--(Model 16K)
35873 Plate--Dial back plate--(Model 16T2
35872 Plate--Dial back plate--(Model 16T3)
5119 Plug--3 contact female plug for speaker cable--(Model 16K)
32289 Pulley--Drive cord pulley and rivet
30881 Resistor--470 ohms, 1 watt
14720 Resistor--1,000 ohms, 1/4 watt
14024 Resistor--2,700 ohms, 1/4 watt
30694 Resistor--3,900 ohms, 1/4 watt
35876? Resistor--12,00 ohms, 3 watts
13298 Resistor, 22,000 ohms, 1/4 watt
12464 Resistor--33,000 ohms, 1/4 watt
12412 Resistor--47,000 ohms, 1/4 watt
12286? Resistor--470,000 ohms, 1/4 watt
12679 Resistor--2.2 meg.., 1/4 watt
13601 Resistor--10 meg., 1/4 watt
35682 Shaft--Tuning shaft
36772 Shield--Power transformer bottom shield
35934 Shield--Power transformer top shield assembly
31364? 964? Socket--Dial lamp socket
36787? Socket--Phono. input socket
31251 Socket--Tube socket
31418 Spring--Drive cord spring
35868 Switch--Push button switch--(Models 16T3? and 16K)
35664? 864? Switch--Range switch--(Models 16T3 and 16K)
35665 Switch--Range switch--(Model 16T2)
35636 Transformer--First I-F transformer
35790 Transformer--Second I-F transformer
35533? 88? Transformer--Power tranformer--10 volts, 25 cycle
35567 Transformer--Power transformer--110 volts, 60 cycle--(Model 16K)
35853 Transformer--Power transformer--less end shields--110 volts, 60 cycles (Models 16T2 and 16T3)
33725 Washer--"C" washer for tuning shaft
8/11/2006 12:24:09 AMMarv Nuce
Thomas,
I can't read the parts list from the NA download, and thats why I need a legible copy. You could have put it in MS word, then attached to a msg to my personal email.
:Ok. I stop here for now. I'll continue with the speaker information later. I am cross-eyed. Just wondering...what do you need the parts list for? The values are printed in the schematic. At any rate, here's the first part. I will type more to-morrow.
:T.
:34785 Board--"Antenna-Ground" board
:35857 Capacitor--Mica trimmer--1 section of 3-30 mmfd. and 1 second of 6-80 mmfd.
:35867 Capacitor--Mica trimmer comprising 2 sections of 9-60? mmfd.
:35869 Capacitor--Mica trimmer comprising 1 sectioin of 10-160 mmfd., 2 sections of
: 25-250 mmfd., 1 section of 50-400 mmfd., and 1 section of 100-540 mmfd. (Models 16T3 and 16K)
:34699 Capacitor--100 mmfd., mica
:12720 Capacitor--100 mmfd., moulded
:34700 Capacitor--120 mmfd.
:13003 Capacitor--180 mmfd.
:12952 Capacitor--330 mmfd.
:35877 Capacitor--720 mmfd.
:13885 Capacitor--5,600 mmfd.
:30803, or perhaps 30303? Capacitor--.0035 mfd (16T2 and 16T3)
:33640 Capacitor--.005 mfd.
:6140 Capacitor--.007 mfd.
:4937 Capacitor--.01 mfd.
:32787 Capacitor--.05 mfd.
:4080? Capacitor--0.2 mfd.
:35858? Capacitor--Electrolytic, comprising 2 sections of 10 mfd., 450 volts, and one section of 20 mfd., 25 volts
:35876 Coil--Coil and resistor assembly [R16 and L2 (L4 in 16T2)]
:36874? or 35874? Condenser--variable tuning condenser
:35801 Control--Tone control--(Models 16T3 and 16T2)
:35935 Control--Tone control--(model 16K)
:35859 Control--Volume control and power switch
:32834 (or 32534?) Cord--Drive cord
:35871 Core--Adjusting core and stud for oscillator coils--(Models 16T3 and 16K)
:35785 or 8? Core--Core and stud for oscillator coil
:35870 Indicator--Station selector indicator
:35856 or 656? Loop--Antenna loop winding
:35855 Loop--Antenna loop complete
:35936 Plate--Dial back plate--(Model 16K)
:35873 Plate--Dial back plate--(Model 16T2
:35872 Plate--Dial back plate--(Model 16T3)
:5119 Plug--3 contact female plug for speaker cable--(Model 16K)
:32289 Pulley--Drive cord pulley and rivet
:30881 Resistor--470 ohms, 1 watt
:14720 Resistor--1,000 ohms, 1/4 watt
:14024 Resistor--2,700 ohms, 1/4 watt
:30694 Resistor--3,900 ohms, 1/4 watt
:35876? Resistor--12,00 ohms, 3 watts
:13298 Resistor, 22,000 ohms, 1/4 watt
:12464 Resistor--33,000 ohms, 1/4 watt
:12412 Resistor--47,000 ohms, 1/4 watt
:12286? Resistor--470,000 ohms, 1/4 watt
:12679 Resistor--2.2 meg.., 1/4 watt
:13601 Resistor--10 meg., 1/4 watt
:35682 Shaft--Tuning shaft
:36772 Shield--Power transformer bottom shield
:35934 Shield--Power transformer top shield assembly
:31364? 964? Socket--Dial lamp socket
:36787? Socket--Phono. input socket
:31251 Socket--Tube socket
:31418 Spring--Drive cord spring
:35868 Switch--Push button switch--(Models 16T3? and 16K)
:35664? 864? Switch--Range switch--(Models 16T3 and 16K)
:35665 Switch--Range switch--(Model 16T2)
:35636 Transformer--First I-F transformer
:35790 Transformer--Second I-F transformer
:35533? 88? Transformer--Power tranformer--10 volts, 25 cycle
:35567 Transformer--Power transformer--110 volts, 60 cycle--(Model 16K)
:35853 Transformer--Power transformer--less end shields--110 volts, 60 cycles (Models 16T2 and 16T3)
:33725 Washer--"C" washer for tuning shaft
8/11/2006 5:16:07 PMThomas Dermody
I can do that, too.
8/11/2006 7:26:22 PMMarv Nuce
Thomas,
Just type as many lines as you want, save, and repeat 'til its done. Thanks for the effort too. I've already found errors in the set now that I have legible copy.
:I can do that, too.
:T.
8/11/2006 10:37:40 PMPeter Balazsy
Boy... what an extra effort from Thomas!!!
It's very comforting Thomas to have you around this forum!
8/14/2006 2:57:28 PMThomas Dermody
Depends on what mood I'm in. Don't know if I'm always an asset.
Sometimes I think I have the hormones of a woman, or at least the swings.
8/9/2006 9:58:47 PMMarv Nuce
I'm just starting to unbutton this old beauty and found a unique (at least for me) voice coil/output transformer/inductor arrangement. The extra inductor appears to be wound within the field coil/pole piece housing. Anyone with unique experiences/failures with this set, please feel free to off load on me before I get buried deeply in "what ifs", "can't believes" and "how'd that happen"
:marv
8/9/2006 10:27:41 PMrickd
:I'm just starting to unbutton this old beauty and found a unique (at least for me) voice coil/output transformer/inductor arrangement. The extra inductor appears to be wound within the field coil/pole piece housing. Anyone with unique experiences/failures with this set, please feel free to off load on me before I get buried deeply in "what ifs", "can't believes" and "how'd that happen"
:marv
Marv, You're not looking at a "hum bucking coil" are you? Looks like it's shown as a separate inductor on the schematic.
::marv
8/10/2006 12:28:35 AMMarv Nuce
Rick,
Now I see, being wound onto the field coil/pole piece could indeed be a hum bucking coil, although a first for me. Although older in years, I've only been at this antique radio stuff for a couple years.
::I'm just starting to unbutton this old beauty and found a unique (at least for me) voice coil/output transformer/inductor arrangement. The extra inductor appears to be wound within the field coil/pole piece housing. Anyone with unique experiences/failures with this set, please feel free to off load on me before I get buried deeply in "what ifs", "can't believes" and "how'd that happen"
::marv
:Marv, You're not looking at a "hum bucking coil" are you? Looks like it's shown as a separate inductor on the schematic.
:::Just downloaded a copy of Riders for this set and the parts list is mostly unreadable as is a lot of the smaller print on the schematic. I've tried enlarging with Adobe Photo and other apps, but it all comes out blurred even worse. Any suggestions?
:::marv
