But why are you using 30s to replace '01As? Cheaper?
:I have been using type 30 tubes to replace 01a's using 2v on the filament as recommended. Will the type 30 work as a grid leak detector as well?
Here is something I wrote up a long time ago:
http://antiqueradios.com/chrs/journal/replacement.html
Except for filament voltage both tubes are similar. The 30 will work as a grid leak detector.
:Bill: Probably, give it a try. Won't hurt.
:But why are you using 30s to replace '01As? Cheaper?
::I have been using type 30 tubes to replace 01a's using 2v on the filament as recommended. Will the type 30 work as a grid leak detector as well?
Yes, 30's are alot cheaper.
