crosley rfl 75 audio output
8/7/2006 2:24:12 PMBill
I'm working on an old crosley rfl 75. The two wire speaker output hooks to an output from a transformer, and a 90v power terminal. I can't figure out why it's wired to a hot lead. Are the leads supposed to hook up to a tranformer on the speaker? I am using an old horn type and the inputs go straight to the voice coil. Please help!
8/7/2006 3:07:47 PMMark
Many of the old horn type speakers had a high resistance voice coil. Quite often it was in the order of 1000-2000 ohms. They typically did feed the 90 volt B+ through the speaker to the plate of the audio output tube. There are also some horn speakers that had a matching transformer. Measure the resistance of your speaker.
MRO
:I'm working on an old crosley rfl 75. The two wire speaker output hooks to an output from a transformer, and a 90v power terminal. I can't figure out why it's wired to a hot lead. Are the leads supposed to hook up to a tranformer on the speaker? I am using an old horn type and the inputs go straight to the voice coil. Please help!
8/7/2006 8:10:17 PMDoug Criner
Mark, what Mark says is correct. But can you point us to a schematic for this set?
Is this a push-pull output? Otherwise, I'm unsure why there is a transformer between the final audio and the speaker terminals.
::I'm working on an old crosley rfl 75. The two wire speaker output hooks to an output from a transformer, and a 90v power terminal. I can't figure out why it's wired to a hot lead. Are the leads supposed to hook up to a tranformer on the speaker? I am using an old horn type and the inputs go straight to the voice coil. Please help!
8/7/2006 11:12:13 PMNorm Leal
Hi
Crosley RFL75 does use a high impedance speaker. Here is the circuit.
http://www.nostalgiaair.org/PagesByModel/694/M0039694.pdf
:Mark, what Mark says is correct. But can you point us to a schematic for this set?
:Is this a push-pull output? Otherwise, I'm unsure why there is a transformer between the final audio and the speaker terminals.
:::I'm working on an old crosley rfl 75. The two wire speaker output hooks to an output from a transformer, and a 90v power terminal. I can't figure out why it's wired to a hot lead. Are the leads supposed to hook up to a tranformer on the speaker? I am using an old horn type and the inputs go straight to the voice coil. Please help!
8/7/2006 11:15:31 PMBill
I got the schematic right here from N air.
Thanx
