Z477 hum following a pop?
8/5/2006 8:24:39 PMY. Lodovici
I've had an Abbotwares Z477 Horse radio for years, given to me by my grandmother. It did not work all this time because the on/off switch was broken. I recently was able to buy the 'guts' (working) of this radio. I swapped the 'guts' in the chassis, planning on doing a lot of work on the original radio.
I was playing the radio one day, and after about 30 minutes or so I heard a POP. It did not seem to affect anything, but I turned it off. After it cooled down a bit, I opened it up and could find nothing obviously wrong. Since then, however, I seem to notice a hum when it is playing. I do not remember hearing it before the pop. It is not noticable when a station is coming in loud and clear, but anytime between stations or when it is not very clear.
Am I nuts or did something change?
Many of the caps were replaced in this radio, but not all. Some appear to be original. Should I start with changing particular caps? I have replacement tubes, but do not want to change them unless necessary.
The schematic for this radio resembles this model by a different company: http://www.nostalgiaair.org/PagesByModel/751/M0009751.pdf
They both use the same tubes and similar cap voltages, etc.
I'm just wondering where I should start. Any help would be appreciated. Thanks!
8/5/2006 11:47:41 PMeasyrider8
Sounds like the line bypass cap let loose. If you are going to use this radio replace the filters and caps, otherwise make it a shelf queen.
8/10/2006 8:09:14 PMY. Lodovici
:Sounds like the line bypass cap let loose. If you are going to use this radio replace the filters and caps, otherwise make it a shelf queen.
:Dave
Thanks for the info. Once the Fall gets here I'll take some time to work on the replacements.
