Battery connector
4/24/2000 9:47:34 PMJim Moore
I have a Zenith 4-K-310 Battery set and it has the original 4 prong male battery connector on it. I plan to make a battery eliminator to power it. Rather then using alligator clips on it,is their anyone that sells the female receptacle that I could make a fake battery and place the battery eliminator in?
Thanks, Jim
4/24/2000 11:26:40 PMNorm Leal
Hi Jim
I have never found a connector. Two suggestions - Look around for an old battery which has this connector or make your own with pins from a tube socket. You could remove 4 pins from an octal tube socket, slide them on the battery connector then pot the pins with Bondo so they hold position. I've done this with good results.
: I have a Zenith 4-K-310 Battery set and it has the original 4 prong male battery connector on it. I plan to make a battery eliminator to power it. Rather then using alligator clips on it,is their anyone that sells the female receptacle that I could make a fake battery and place the battery eliminator in?
: Thanks, Jim
5/8/2001 9:16:20 PMgrace
: Thanks, Jim
