Here is the schematic:
http://www.nostalgiaair.org/PagesByModel/363/M0021363.pdf
The IF frequency is probably set low. The signal generator may not have been exact?
When the IF frequency is low the oscillator is operating lower in frequency. It requires more capacity change to cover the range at lower frequencies.
IF Frequency of this radio is 455. Try aligning it at 465 and see if there is improvement.
Look at your tuner. Be sure the plates on the smaller section aren't bent out.
:Hi, I just restored this set and the station that is playing is not what the dial is indicating so the station at 580 is indicating 550 but the sations get more accurate above 900. The set was aligned and the usual bad parts replaced. Any ideas? Thanks!
