:The transformers should not be replaced. There are no shorted windings. Wiggling the transformers will not loosen a shorted winding. THe windings are covered in wax. Your problem is most likely bad mica condensers. Most likely there is a sheet of mica with silver sections deposited on each side of it. There will be two sections of silver on each side. The opposing sides of silver form the condenser for each winding of the transformer, totalling two condensers. The mica oxidizes and makes poor contact, or disappears all together. You must scrape the mica out so that there is none left to make contact/short. This is a very tedious and delicate operation. Then replace with mica condensers from 50 to 250 pF. Use one per coil. Select condensers that allow the IF to be brought to resonance. Mount the condensers under the can if you wish, so that you may change them until a correct value has been found. The correct value for the primary and secondary of one transformer might not be the same as that for another. The correct value for the primary of one transformer might not be the correct value of the secondary of that same transformer, either. The correct value for one winding will be correct for all others with the same DC resistance and same physical appearance. DO NOT TOUCH THE ADJUSTMENT SLUGS AT THIS TIME!!!! Select the condenser value that yields the strongest signal (use a signal generator to produce this signal). Then, once the closest value has been found (condensers don't usually come in infinite values...you only have so many to choose from, even from the best supply houses), touch up on the slugs and put your radio back together. Enjoy! Perhaps you might want to touch up on the other controls, too.
:Thomas
Best Regards,
Bill
:If the transformers have plastic bases, the capacitors could be molded inside of the plastic.
:T.
