:Hello All,
: Now that I had a nice bright beautiful raster, I lost vertical height. I was trying to adjust the vertical hold when the vertical deflection disappeared.
: I'll solve this little problem, and everything should work fine.
: Wow! That horizontal line can be made very bright on my check tube.
:Dave
:Hello Again All,
: The vertical oscillator is working "ok" but it seems that it wont sync. It may be ok. I must have thrown the Horizontal Alignment off So I'll have to borrow an oscilloscope and make it right after I figure out why I am only receiving one channel even though the tuner is connected. So I better re-name this thread KCS-28-1 troubles.
: I cannot tell how good the picture looks with this check tube. I only know that I now have high voltage. I will soon have a 10BP4. That should make things a lot easier.
:Thanks,
:Dave
::Hello All,
:: Now that I had a nice bright beautiful raster, I lost vertical height. I was trying to adjust the vertical hold when the vertical deflection disappeared.
:: I'll solve this little problem, and everything should work fine.
:: Wow! That horizontal line can be made very bright on my check tube.
::Dave
As for the cable connection, that should be no problem there , with that possibility of having even a higher quality of signal coming into the set on channels 2-13 …or on channel 3 if it should be from a cable box converter output.
Thumbnail reference for you and the peanut gallery:
http://img174.imageshack.us/img174/259/kcs28vertcktxc0.gif
Give us an update
73’s de Edd
