Philco 53-1750 table with wings, needs repair
6/27/1998 2:15:47 AMNick Brown
At a garage sale I found a Philips AM-SW-Phonograph
Model Number 53-1750. It has a 60 watt amp.
The cabinet is solid mahogany and messures
26"H x 26"D x 18"W(30"W with the wings extended
The nobs are on the front and station locator
is on the top.
The AM works but has a hum.
The phono works but needs new rubber mounts.
Shortwave doesn't work.
I'd like to find schematics, a tube source for 50Y7GT
tube and repair sources. And year of manufacture.
The serial number is 0211062301
It makes a great end table but I'd like to get
it working right.
Thanks in advance for your help.
Nick Brown
nick@ameritech.net
6/27/1998 12:01:22 PMNorm Leal
: At a garage sale I found a Philips AM-SW-Phonograph
: Model Number 53-1750. It has a 60 watt amp.
: The cabinet is solid mahogany and messures
: 26"H x 26"D x 18"W(30"W with the wings extended
: The nobs are on the front and station locator
: is on the top.
: The AM works but has a hum.
: The phono works but needs new rubber mounts.
: Shortwave doesn't work.
: I'd like to find schematics, a tube source for 50Y7GT
: tube and repair sources. And year of manufacture.
: The serial number is 0211062301
: It makes a great end table but I'd like to get
: it working right.
: Thanks in advance for your help.
: Nick Brown
: nick@ameritech.net
Hi Nick
Your radio was made in 1953. With a lot of the Philco's the first 2 numbers of the model number is the year manufactured.
Sam's Index lists your radio as being in #203-7. Most libraries can order the Sam's Photofact which has the schematic.
Antique Electronic Supply has the 50Y7GT tubes and lists them for $3.50.
Hum in your radio is generally caused by bad filter caps. These caps dry out over time, loosing capacity, and allowing hum.
6/29/2000 3:55:55 PMchuck braun
use 50L6 instead of 35L6, 25Z6 instead of 50Y7, and use shunt resistor across entire filament string except for rectifier.
try Antique Electronics Supply for 50Y7 tube.
