Now I have another question.
I’m going to replace the large electrolytic capacitors in my radio’s power supply circuit. The radio I am working on is a Zenith 10s566 btw. I could replace the caps with generic electrolytic caps but in this case I’m inclined to replace the caps with metallized polypropylene film caps. Is there a downside to doing that other than the fact they cost a few dollars more?
I fail to see any benefit in doing so. Haven't looked at the schematic yet, but I suspect you will need quite a bunch of poly caps to replace any electros in a radio. Aside from cost and _size_, there is no benefit in doing so. Good electros should last quite a long time if you use the radio once in a while.
The physical size of film caps would be much larger. Maybe a problem to fit them in?
What would be the reason to use film caps?
I suggest that you stick with electrolytics, unless you want some really massive poly caps under the chassis. Electrolytics are pretty good, and they keep getting better. With regular use, they should last a long time (possibly 50 years or more).
