Well I just had a very nice and unusual (to me) antenna learning experience a few mineuts ago on my work bench.
I have a Bendix 526a upside down playing there nicely after I just recapped it. It has a loop antenna which happens to be facing toward the front of my bench.
I was about to start work on a Zenith 6d-614 which also has a type of square-box-shapped loop antenna too.
As I pulled the Zenith out of it's case I set it down near the Bendix 525 such that the two antennas just happened to be about 2 inches away from each other.
Now the Zenith is without power, yet as the two units came close... the Bendix suddenly went up almost double in signal and output!
As I positioned the Zenith further and nearer I found that the the optimum distance is just about 2 inches. I tried rotating it in various angles as well yet 2 inches and straight aligned was the optimum.
... but the real interesting thing was... that I found that the Bendix signal got even stronger as I "tuned" the Zenith dial (no power) to the SAME station as the Bendix.
It was so funny tuning the un-powered Zenith and listening to the Bendix volume go up and down!
Just having an RF-only-powered antenna-tank-circuit in close proximity coupled it's signal right over from it to the other antenna.
I don't know what I learned here yet lol.
... perhaps that double antennas work better than one?? lol
I don't know. All I know is I just discovered it and I'm repoting back to headquarters here...
Having a second turned circuit nearby can bring up the signal and narrow the bandwidth. The same idea can be used in a radio using more than one tuned circuit. Try tuning your Zenith to another frequency. Signal strength on your Bendix will go down.
You will find crystal sets made this way. Two or 3 tuned circuits will sharpen tuning.
:I know that there are plenty of seemingly unexplainable antenna tricks. I've seen ads for AM antenna signal boosters that you place near your radio and supposedly get improved performance of mucho buck$.
:Well I just had a very nice and unusual (to me) antenna learning experience a few mineuts ago on my work bench.
:I have a Bendix 526a upside down playing there nicely after I just recapped it. It has a loop antenna which happens to be facing toward the front of my bench.
:I was about to start work on a Zenith 6d-614 which also has a type of square-box-shapped loop antenna too.
:As I pulled the Zenith out of it's case I set it down near the Bendix 525 such that the two antennas just happened to be about 2 inches away from each other.
:Now the Zenith is without power, yet as the two units came close... the Bendix suddenly went up almost double in signal and output!
:As I positioned the Zenith further and nearer I found that the the optimum distance is just about 2 inches. I tried rotating it in various angles as well yet 2 inches and straight aligned was the optimum.
:... but the real interesting thing was... that I found that the Bendix signal got even stronger as I "tuned" the Zenith dial (no power) to the SAME station as the Bendix.
:It was so funny tuning the un-powered Zenith and listening to the Bendix volume go up and down!
:Just having an RF-only-powered antenna-tank-circuit in close proximity coupled it's signal right over from it to the other antenna.
:I don't know what I learned here yet lol.
:... perhaps that double antennas work better than one?? lol
:I don't know. All I know is I just discovered it and I'm repoting back to headquarters here...
Maybe I am not using the word 'gain' properly?
I didn't mean to split hairs over the use of the word 'gain' since I was just marveling at the improvement, "gain" or whatever you call it that was caused by the proximity of the two antennas.
By sharpening the tuning it must effectively produce a higher value of RF signal voltage signal somehow ...
....And then isnn't that creating greater 'gain' from the antenna circuit as it appears to the input of 1st mixer/osc Rf amp? ... no?
Doesn't greater RF signal from an antenna tank circuit equate to greater gain? Or does "gain" only relate to the amplification factor of an active circuit?
I would think that if the volume got way louder at the audio stage ...then somewhere somehow... there was a signal 'gain'... no?
...if adding the other non-powered tuned circuit in close proximity to the powered unit created the volume increase effect by sharpening the antenna tank circuit in the powered unit... there must have been some actual greater signal present at the first stage... so... wasn't there some improved signal or greater "gain" coming from the antenna?
:Thanks.. marv and norm but why do you say there was not increased gain?
:Maybe I am not using the word 'gain' properly?
:I didn't mean to split hairs over the use of the word 'gain' since I was just marveling at the improvement, "gain" or whatever you call it that was caused by the proximity of the two antennas.
:By sharpening the tuning it must effectively produce a higher value of RF signal voltage signal somehow ...
:....And then isnn't that creating greater 'gain' from the antenna circuit as it appears to the input of 1st mixer/osc Rf amp? ... no?
:Doesn't greater RF signal from an antenna tank circuit equate to greater gain? Or does "gain" only relate to the amplification factor of an active circuit?
:I would think that if the volume got way louder at the audio stage ...then somewhere somehow... there was a signal 'gain'... no?
:...if adding the other non-powered tuned circuit in close proximity to the powered unit created the volume increase effect by sharpening the antenna tank circuit in the powered unit... there must have been some actual greater signal present at the first stage... so... wasn't there some improved signal or greater "gain" coming from the antenna?
David,
I'm not familar with the device you noted, but if the design/application is similar in nature to the earlier noted discussion, yes.
:Is this how a Select-A-Tenna AM Radio Antenna made by Crane works?
