unknown capacitor
7/13/2006 5:12:04 PMGeorge
Hi fellows, I am recapping a B600 zenith trans-oceanic, I came across a cap I am not sure of, it goes between the IL6 converter and coil L5, the schematic shows it as c15 and listed as #250 no uf or pf indication, do I consider this as a .25 ? the color code on this axel ceramic is violet, red, green, brown and white, Im confused?? George
7/13/2006 5:54:47 PMNorm Leal
Hi George
That's C15, 250pf. I wouldn't change unless the cap is shorted.
http://www.transoceanic.nostalgiaair.org/600/B600.pdf
:Hi fellows, I am recapping a B600 zenith trans-oceanic, I came across a cap I am not sure of, it goes between the IL6 converter and coil L5, the schematic shows it as c15 and listed as #250 no uf or pf indication, do I consider this as a .25 ? the color code on this axel ceramic is violet, red, green, brown and white, Im confused?? George
7/13/2006 6:04:54 PMGeorge
:Thanks Norm, I couldn't figure out the color code on this cap, didn't seem to relate to 250pf
Hi George
: That's C15, 250pf. I wouldn't change unless the cap is shorted.
:http://www.transoceanic.nostalgiaair.org/600/B600.pdf
::Hi fellows, I am recapping a B600 zenith trans-oceanic, I came across a cap I am not sure of, it goes between the IL6 converter and coil L5, the schematic shows it as c15 and listed as #250 no uf or pf indication, do I consider this as a .25 ? the color code on this axel ceramic is violet, red, green, brown and white, Im confused?? George
