:Does anyone know the impedance values of the primary and secondary windings of the interstage transformer that drives the two 47s?
Doug, Thank you for your recommendation. I may get this old Crosley talking yet! Jim
:RadioDaze has two xfmrs, either of which should work. I would try HX124A, which is a a 1:3 C.T. audio xfmr.
:::Does anyone know the impedance values of the primary and secondary windings of the interstage transformer that drives the two 47s?
:Doug, Thank you for your recommendation. I may get this old Crosley talking yet! Jim
::I just finished the restoration of a Crosley 124. I have a couple of good 1930 vintage single plate to Push-Pull pull grid audio transformers that should work in this application, and are of such a size that thewy will easily fit into your chassis. please e-mail if interested. To prevent future burnouts, and improve fidelity it is adviseable to get the DC out of the primary of these interstage units. Just olad the plate of the 224 with a 50-75K resistor, ground one side of the proimary, and couple the other side of the primary to the plate of the 224 through a 1/4 MFD condenser.
::RadioDaze has two xfmrs, either of which should work. I would try HX124A, which is a a 1:3 C.T. audio xfmr.
::::Does anyone know the impedance values of the primary and secondary windings of the interstage transformer that drives the two 47s?
::Doug, Thank you for your recommendation. I may get this old Crosley talking yet! Jim
:My Crosley 124 has a "27" tube output coupled to one end of the primary of the interstage (that drives the 2 "47"s) through a choke and then coupled to the other end of the primary through a .05 mf cap in series with a potentiometer. This side of the primary also connects to ground through a .1 mf cap. Seems that we have different versions of a Model 124. Thanks for the feedback.
:::I just finished the restoration of a Crosley 124. I have a couple of good 1930 vintage single plate to Push-Pull pull grid audio transformers that should work in this application, and are of such a size that thewy will easily fit into your chassis. please e-mail if interested. To prevent future burnouts, and improve fidelity it is adviseable to get the DC out of the primary of these interstage units. Just olad the plate of the 224 with a 50-75K resistor, ground one side of the proimary, and couple the other side of the primary to the plate of the 224 through a 1/4 MFD condenser.
:::RadioDaze has two xfmrs, either of which should work. I would try HX124A, which is a a 1:3 C.T. audio xfmr.
:::::Does anyone know the impedance values of the primary and secondary windings of the interstage transformer that drives the two 47s?
:::Doug, Thank you for your recommendation. I may get this old Crosley talking yet! Jim
:Yes, but the chole is an RF choke and you still have DC flowing through the transformer. I was simply suggesting that if you get the DC out of thr primaty of the audio transformer winding that you cnn greatly increase its longevity, and also imprrove the circuit's fidelity.
::My Crosley 124 has a "27" tube output coupled to one end of the primary of the interstage (that drives the 2 "47"s) through a choke and then coupled to the other end of the primary through a .05 mf cap in series with a potentiometer. This side of the primary also connects to ground through a .1 mf cap. Seems that we have different versions of a Model 124. Thanks for the feedback.
::::I just finished the restoration of a Crosley 124. I have a couple of good 1930 vintage single plate to Push-Pull pull grid audio transformers that should work in this application, and are of such a size that thewy will easily fit into your chassis. please e-mail if interested. To prevent future burnouts, and improve fidelity it is adviseable to get the DC out of the primary of these interstage units. Just olad the plate of the 224 with a 50-75K resistor, ground one side of the proimary, and couple the other side of the primary to the plate of the 224 through a 1/4 MFD condenser.
::::RadioDaze has two xfmrs, either of which should work. I would try HX124A, which is a a 1:3 C.T. audio xfmr.
::::::Does anyone know the impedance values of the primary and secondary windings of the interstage transformer that drives the two 47s?
::::Doug, Thank you for your recommendation. I may get this old Crosley talking yet! Jim
:JWM,
: This is a common problem with the Crosley 124. I also have one that needs an interstage transformer and I haven't done anything with it for over 10 years. Now that I know where to get a replacement, I will probably finish the electronic restoration. Now I I also know why they had problems. Thanks for posting this question. Thanks to everyone else for the solutions to the problem.
:Dave
