I got it playing pretty easily, but ran into something interesting.
This set has two phono jacks for the loudspeaker - one jack labeled LOUD, which ties into the output of the 2nd audio stage, and another jack, labeled MEDIUM, which ties into the output of the 1st audio stage.
The LOUD output gave poor frequency response, mostly bass and very little treble. The MEDIUM output sounded good (but with lower volume, of course). After shuffling tubes around with no change, the 2nd audio interstage xfmr seemed to be the culprit, even though its primary and secondary winding resistances checked out OK.
I replaced the 2nd audio xfmr with a Hammond 124A, which is a usual 1:3 Stancor 53C knock-off. The frequency response improved greatly.
I wonder what goes wrong with such a xfmr to cause it to sound lousy? The bad xfmr itself was a replacement (from many years ago), so maybe it was poor to begin with. Construction-wise, it looked well built with plenty of iron and the ratio was correct.
All's well that ends well, I suppose.
Also, poor impedance matching makes for poor response.
I have two almost identical radios. A Bendix 526a and a Bendix 110W
They both use almost identical schematics.
The 110w is a few years newer model.. but still the same basic circuit.
I was playing these two raadios when I noticed how totally great the 110 sounded and the 526 was just average ordinary and plain sounding.
The difference was almost astoundingly richer.. brighter, more full... seemed like I could hear things that weren't even there in the 526 model!!
I went about comparing componetns and actually rewiring both to have the "EXACT" same values and components.. but still the 110 sounded richer... I mean REALLY richer..
I finally took the speaker from the 110 and put it on the 526...and that was it!
It was just the speaker.
They looked similar.. maybe even the same bendix stock number.. but I'm not sure of that.
However... that made ALL the difference in the world. Now I wish I knew what elements in that great little speaker go to make it sooo great? It seems to have the same sized magnet and general construction.. just a 4" speaker... but wow!
I doubt that either of your speakers has an aluminum voice coil, as this was very rare at that time. About the only manufacturer that I can think of that used aluminum was Stromberg Carlson. Most other radio manufacturers used copper. Aluminum responds a ton better to the high frequencies due to its lighter weight.
The other thing that makes a speaker sound good is a light cone, or a really heavy one. For bass only, a really heavy cone is nice, one that has a resonance at the bottom or below the human hearing range. For a speaker that must respond to all frequencies, a resonance in a pleasant area is nice, or, ideally, a resonance above the human hearing range. Don't expect this with a paper cone, though. Paper cones usually have a resonance right in the mid-range area. The better ones will have this resonance where it sounds good.
MRO
Here is a completely different answer since you mentioned the transformer was replaced before. Both AES and PTOP had defective audio interstage transformers. I made frequency measurements along with others and notified both suppliers.
Here is what happened. These were transformers with a center tapped secondary. Both half's of the secondary were wound together, side by side. This doesn't seem like a problem but it increases capacity between outside wires of the windings. Capacity may only increase to .005 mf? I still have information in the computer if someone is interested. This increase in capacity wouldn't be bad except impedance is 90,000 ohms with only tube grid loading. Even .005 mf will greatly reduce high frequency response.
I am almost sure this is the problem you found.
:I'm working on a Freed-Eisemann Model NR-12, a battery-powered TRF with four '01A tubes. Schematic: http://www.nostalgiaair.org/PagesByModel/880/M0039880.pdf
:I got it playing pretty easily, but ran into something interesting.
:This set has two phono jacks for the loudspeaker - one jack labeled LOUD, which ties into the output of the 2nd audio stage, and another jack, labeled MEDIUM, which ties into the output of the 1st audio stage.
:The LOUD output gave poor frequency response, mostly bass and very little treble. The MEDIUM output sounded good (but with lower volume, of course). After shuffling tubes around with no change, the 2nd audio interstage xfmr seemed to be the culprit, even though its primary and secondary winding resistances checked out OK.
:I replaced the 2nd audio xfmr with a Hammond 124A, which is a usual 1:3 Stancor 53C knock-off. The frequency response improved greatly.
:I wonder what goes wrong with such a xfmr to cause it to sound lousy? The bad xfmr itself was a replacement (from many years ago), so maybe it was poor to begin with. Construction-wise, it looked well built with plenty of iron and the ratio was correct.
:All's well that ends well, I suppose.
Just for grins, I measured the capacitance between the primary and secondary windings. For the "bad" xfmr, it's 408pF, and for a new Hammond 124A, it's only 57pF. I'm not sure what to make of that.
:Hi
: Here is a completely different answer since you mentioned the transformer was replaced before. Both AES and PTOP had defective audio interstage transformers. I made frequency measurements along with others and notified both suppliers.
: Here is what happened. These were transformers with a center tapped secondary. Both half's of the secondary were wound together, side by side. This doesn't seem like a problem but it increases capacity between outside wires of the windings. Capacity may only increase to .005 mf? I still have information in the computer if someone is interested. This increase in capacity wouldn't be bad except impedance is 90,000 ohms with only tube grid loading. Even .005 mf will greatly reduce high frequency response.
: I am almost sure this is the problem you found.
You showed a difference in capacity. Even a ratio of 7:1 is quite a difference. I used HP 4260A. Windings don't have much of an effect with this HP bridge.
I am sure the way wire was wound is your problem. I worked on this for a long time. Someone actually unwound a transformer to prove the problem.
:Thanks, Norm. Are we talking about the effective shunt capacitance across, say, the primary terminals of the xfmr? If so, I guess there is no way to really measure that capacitance, at least with my equipment -- we'd have to compute it from the winding geometry.
:Just for grins, I measured the capacitance between the primary and secondary windings. For the "bad" xfmr, it's 408pF, and for a new Hammond 124A, it's only 57pF. I'm not sure what to make of that.
::Hi
:: Here is a completely different answer since you mentioned the transformer was replaced before. Both AES and PTOP had defective audio interstage transformers. I made frequency measurements along with others and notified both suppliers.
:: Here is what happened. These were transformers with a center tapped secondary. Both half's of the secondary were wound together, side by side. This doesn't seem like a problem but it increases capacity between outside wires of the windings. Capacity may only increase to .005 mf? I still have information in the computer if someone is interested. This increase in capacity wouldn't be bad except impedance is 90,000 ohms with only tube grid loading. Even .005 mf will greatly reduce high frequency response.
:: I am almost sure this is the problem you found.
