Crosley 66TW squeal on stations
4/16/2000 9:34:04 PMLarry Tucker
Hello:
I am restoring a Crosley 66TW. I have replaced all caps
including the mica, resistors that were over 10% in
marked value, NOS tubes. The radio is very very sensitive
on BC and SW. But, I am getting a squeal on all stations
which is worse on BC. Not a loud squeal but the weaker
the station the more noticable. Seems worse on the low end
of the BC band. Sounds like a SW receiver with the BFO
turned on but weak. The pitch lowers as the station is
zeroed in to center and starts up again in pitch as you move
off.
I had problems with alignment as the first IF seemed to
pull the local osc. off frequency and if peaked to high
the IF would go into oscillation.
I also had some problems with the local osc. tracking as there
seems to be 2 adjustments, one on the tuning cap which
I suspect is for SW (?) and one on the chassis. There are
3 timmers on chassis, 1 for BC, middle one for ? and most front one
for SW. I do have the schematic but no alignment
instructions.
Any ideas out there? Thanks in advance.
Larry Tucker
4/17/2000 9:50:35 AMNorm Leal
Hi Larry
The IF stage may be going into oscillation. Be sure all bypass caps are in place. If you are using a glass IF Amplifier tube slielding may help. If all else fails slightly detuning an IF Transformer should stop the problem.
I'll look for alignment instructions.
: Hello:
: I am restoring a Crosley 66TW. I have replaced all caps
: including the mica, resistors that were over 10% in
: marked value, NOS tubes. The radio is very very sensitive
: on BC and SW. But, I am getting a squeal on all stations
: which is worse on BC. Not a loud squeal but the weaker
: the station the more noticable. Seems worse on the low end
: of the BC band. Sounds like a SW receiver with the BFO
: turned on but weak. The pitch lowers as the station is
: zeroed in to center and starts up again in pitch as you move
: off.
: I had problems with alignment as the first IF seemed to
: pull the local osc. off frequency and if peaked to high
: the IF would go into oscillation.
: I also had some problems with the local osc. tracking as there
: seems to be 2 adjustments, one on the tuning cap which
: I suspect is for SW (?) and one on the chassis. There are
: 3 timmers on chassis, 1 for BC, middle one for ? and most front one
: for SW. I do have the schematic but no alignment
: instructions.
: Any ideas out there? Thanks in advance.
: Larry Tucker
