SMD (surface Mounted Devices) are very hard to work with unless you have a good magnifying glass and proper soldering equipment. Are you trying to remove a part? If so all leads needs to be heated at one time. You might be able to use a solder sucker if you can't heat all leads. Soldering individual leads isn't hard but watch for bridging. Leads are close together.
: help me someone can information me about rework
: soldering SMD
