7 pin tube (old type) question
6/27/2006 10:17:11 PMNick
6/27/2006 10:21:25 PMNick
:I bought an old Supreme tube tester so I could test vintage tubes like a 6A7 with seven pins. The Supreme tester has a 7 pin socket but the tube does not fit (the pins are spaced closer and smaller than the socket). Were there different size tubes available way back when? Nick
6/28/2006 12:06:14 AMNorm Leal
Hi Nick
There were two size 7 pin bases used on early radio tubes. 6A7 uses the smaller spacing. Type 59 has larger spacing. Many tube testers have a 7 pin socket that will fit either spacing.
::I bought an old Supreme tube tester so I could test vintage tubes like a 6A7 with seven pins. The Supreme tester has a 7 pin socket but the tube does not fit (the pins are spaced closer and smaller than the socket). Were there different size tubes available way back when? Nick
6/28/2006 8:42:33 AMIvan H Copas
Hi Nick. I have had good luck adding extra sockets to several tube testers. Often without having a schematic. The 'Precise' testers origionally had a blank spot on the front for an added socket. All had the sockets paralled. Hope this helps. Ivan Copas
