Last night though I was trying to do this to a speaker whose outside diameter is 5-1/4 inches.
But..I had only two replacement cone sizes that were close in size, a 4-1/2" which was way too small and a 6-1/8" which was way too big.
So I thought I could just cut a slit in it and overlap the two edges like a "tighter paper funnel"... to reduce the outer diameter. Well...that was correct but still it won't work because the funnel just gets that much deeper too and that was just too steep of an angle to fit.
Well the cones are so cheap I decided to get brave and experiment.
The solution was to cut the 6-1/8" replacement cone into 6 sections or pieces like a pizza.
Then the outer edges of each "slice" could then be easily glued to fit on the outer rim... and the pointed end can be glued over my 1/2 dollar center part easily as well.
Then all I needed to do was overlap each slice as I glued them down and then just run a bead of glue on each overlap joint.
Well it works!! ...and sounds terrific too.
Take a look at the result:
http://www.pbpix.com/pizzaspeaker.jpg
Bob P.
:I have found that restoring fragile ripped old cones is effective and easy with some very low cost (39 cents to 49 cents or so) strong and beautiful replacement cones sold through Electronix.com
:I usually cut away all the old cone from the outer edge down to a small 1/2 dollar-sized circle remaining near the center. I then take the new cone and cut a hole slightly larger than the 1/2 dollar area. I glue the new cone over the old section in the center and then just glue the outer rim of the new cone to the frame rim... Beautiful, fast easy and sounds beautiful too.
:Last night though I was trying to do this to a speaker whose outside diameter is 5-1/4 inches.
:But..I had only two replacement cone sizes that were close in size, a 4-1/2" which was way too small and a 6-1/8" which was way too big.
:So I thought I could just cut a slit in it and overlap the two edges like a "tighter paper funnel"... to reduce the outer diameter. Well...that was correct but still it won't work because the funnel just gets that much deeper too and that was just too steep of an angle to fit.
:Well the cones are so cheap I decided to get brave and experiment.
:The solution was to cut the 6-1/8" replacement cone into 6 sections or pieces like a pizza.
:Then the outer edges of each "slice" could then be easily glued to fit on the outer rim... and the pointed end can be glued over my 1/2 dollar center part easily as well.
:Then all I needed to do was overlap each slice as I glued them down and then just run a bead of glue on each overlap joint.
:Well it works!! ...and sounds terrific too.
:Take a look at the result:
:http://www.pbpix.com/pizzaspeaker.jpg
Marv:
I take it... you don't approve?
... perhaps there's another idea or solution that you have that I didn't think of?
::Looks like a cheap pizza to me, and without the sauce
::marv
:Marv:
:I take it... you don't approve?
:... perhaps there's another idea or solution that you have that I didn't think of?
Keep the cigs away from the acetone! (if you smoke)
The speaker paper that you see in that picture is tough as nails!.. I mean strong and reindorced w/some kind of synthetic fibes too it seems.. heavy tough stuff.
I didn't use all water based glue. I've found some great stuff caled "Fabri-tac" a fabric & gen purpose adhesive.. it is very nice when positiong things as it is tacky and sets up soon but moveable and permanet.. even washable on fabrics so it's not water soluble.
You can get sever great glues like this in the fabric store now..Another great one is "Sobo" craft & fabric glue... fast setting all purpose.. nice!
Both these glues come in small squeeze bottles.
So why do you think it would warp or squeal or whatever?
Whenever I do something I do it so it will work properly or I'll abandon it for another solution... don't you?
This idea was the only available solution I had here.
Otherwise I'd be searching the web for weeks trying to find the 5-1/4" cones or another dynamic speaker... in the mean time the radio waits on my bench or gets stuck back in the corner.
.. why not solve it with what I can... evaluate the results and move on?
If it's not a great solution I can still always hunt around for the other more perfect parts... but in the mean time.. I've accomplished someting... and that makes me feel better than sitting around waiting... lol
Reminds me of that old cartoon where two vultures sitting on a branch looking bored and waiting for something to die so they can eat.
... So one vulture turns to the other one and says, "Hell..I'm so bored... I'm going out and kill me something"...
So.. I guess that's me... the bored vulture.... lol
My sign off initails.
If you go to the electronix site and not the electronics site you can search the loudspeaker section and find the cones rather easily.
MRO
http://www.electronix.com/catalog/advanced_search_result.php/keywords/cone/sort/1a/page/2
