Tube ID
6/19/2006 9:20:57 PMJK
I have a rectifier tube, i can't find any numbers. It looks just like an 80, but this one is much larger, still has the 4 pin base. Any thoughts????
Thanks JK
6/19/2006 9:40:27 PMrghines1
What is its dimensions? Maybe a 5Z3? Richard
6/19/2006 10:38:08 PMNorm Leal
Hi
A 5Z3 is the same size as 5U4G except it has only 4 pins. An 83 is same size, with 4 pins but is a mercury vapor rectifier. The 83 will glow purple in operation.
:What is its dimensions? Maybe a 5Z3? Richard
6/25/2006 11:20:19 AMJK
:I have a rectifier tube, i can't find any numbers. It looks just like an 80, but this one is much larger, still has the 4 pin base. Any thoughts????
:Thanks JK
The only nubers i can find on the tube is 322mt3, the manufacturer is Tung-Sol Thanks for your replies JK
6/25/2006 12:49:34 PMNorm Leal
Hi JK
Tung Sol did have their own set of numbers on some tubes. Test it as an 80. A 5Z3 will test strong. An 83 will also but show purple color in operation.
Lud Sibley would know for sure.
::I have a rectifier tube, i can't find any numbers. It looks just like an 80, but this one is much larger, still has the 4 pin base. Any thoughts????
::Thanks JK
:The only nubers i can find on the tube is 322mt3, the manufacturer is Tung-Sol Thanks for your replies JK
