Or the easy way is to take some duct tape and tape the signal generator to the top or side of the radio ... whereever it looks nice. Then tape the two power switches together... keep the 455kc signal wired in... and .....your problem is solved...
Could be a weak 1R5, check the filament voltage it could be low. It should have the caps and lytics replaced before you do any trouble shooting.
:Or the easy way is to take some duct tape and tape the signal generator to the top or side of the radio ... whereever it looks nice. Then tape the two power switches together... keep the 455kc signal wired in... and .....your problem is solved...
