:Wow... that's saying something compared to AM radios these days.. what's the circuit design secret for pure no static sound??
At any rate, here's an auto AM radio that sounds terriffic, and is static free, too. This radio actually makes music sound great on AM (like most old radios do). There will be slight static if steel ignition wires are used. I prefer steel, though, because it gives me a better spark. If out in the middle of nowhere, you'll get a rushing sound even with resistor wires. This is due to static in the wheels, among other things. I never did fill my wheels with anti-static powder. Oh well.
http://www.nostalgiaair.org/PagesByModel/442/M0025442.pdf
Note: my radio is the one with octal and 7 pin tubes. It doesn't have loktals, though both types were available. A great improvement in power and lack of current drain can be had by gutting an 0Z4 and replacing the innards with 600 volt diodes. Then insert this in the 6X5 socket (same pin out). ...More power, less filament drain.
:http://www.dsprelated.com/showmessage/58085/1.php
High-voltage transmission lines will generate static -- that can be worsened by dirty insulators or sharp edges in the hardware that support the conductors, e.g. nuts and bolts. The field strength at those sharp points can be high enough to cause discharge. The discharge will have all kinds of frequencies in it, but will be modulated by the 60-Hz. You're really not picking up the pure 60 or 120 Hz (which would be a hum, not a buzz).
A new transmission line may generate a lot of static because the hardware edges are sharp. As time goes on, those edges and points become less sharp, so the static is reduced.
I don't think a pure 60-Hz signal would be picked up by a standard AM radio unless it somehow jumped straight into the radio's audio section. This, I suppose, could happen if the field strength was strong enough.
Anyway, if the reply has anything to do with what I wrote, I was just adding my two cents worth. I know that the guy was originally talking about buzz. What I was saying is that my car radio doesn't ever pick up buzz or static (except in thunder storms or slight static when I use steel ignition wires). Only on rare occasion does it pick up a deep booming hum, and it's only when I drive under super high voltage wires. My radio is amazing. It even fairs well under bridges. It obviously gets quieter, but the AVC works overtime to pull in the signal anyway. In clear open spaces it is just jam packed with stations even in the day. The thing I like the most about this radio is that it has push-pull output. I got it for only $10. These two keep me from getting the original 1951 Chevrolet radio, which has a single 6V6 for the output, and often costs over $200.
I wonder if your hum comes in through the antenna somehow or if it excites the car's body and then jumps into the radio's audio section.
