Thomas,
The wire didn't look old enough to be original, however, it did look like an old style wire. It was a small rubber covered wire inside a braided metal shield and then the sheild covered with black woven heavy cloth material. First I snipped the wire at the switch and tried the radio. I did notice a little inter-station hum and I reasoned that was because the tube was no longer grounded. So, then I cut the wire away from the two pins and tried it again. There was a little less hum then. I plan to connect a wire from the chassis to pin 1 of the power tube tommorrow. The radio is in our basement ratskeller and I have it connected to a 75' long wire outdoor antenna. There are very few vacent places on the dial for the hum to sneak into. Also, I noticed that the tone control has a much greater range. Hum bucking may have been the intent of some long ago service man. This past weekend I rigged up an antenna switch to route the antenna from the upstairs computer/radio room to the basement Zenith. I'm really beginning to like this old timey radio stuff. My next quest is to find and restore a Truetone D726 like my parents had when I was a child.
Will
