Mark, the box on the computer is metal, I will have to check on the ground, but his previous computer in the same outlet and room didn't give me any trouble. On the antenna, before I invest the money and time, is there an easy way to test that theory? Would running a wire up the side of the house or up a tree prove or dis-prove that logic?
Steve
::One suggestion is to try installing an outside antenna. Also is the computer properly grounded and in a metal enclosure?
::MRO
:Mark, the box on the computer is metal, I will have to check on the ground, but his previous computer in the same outlet and room didn't give me any trouble. On the antenna, before I invest the money and time, is there an easy way to test that theory? Would running a wire up the side of the house or up a tree prove or dis-prove that logic?
:Steve
Richard
:Thanks for all the help so far. I have determined that the computer is properly grounded. Turning off the monitor didn't help. I called the place that built the computer and he says that the power supply is much larger than the one in the older model and that is what is causing the RF interference and that there is no solution other than powering down the CPU when I turn on a radio. That is not a good answer, but maybe Marv is right and silence is golden at times. Still open for any other suggestions...
You can find quality class "b" cases on line at reasonable prices however.
Here's a little info.
MAKE sure you read the very last line and show it to the dealer.
FCC RFI limits are set in order to prevent computer equipment from interfering with the operation of radio and television receivers. Two different limits have been set, depending on the typical application and marketing of the computer equipment. The class "A" FCC limits are for equipment intended for use in commercial and industrial environments. The more stringent class "B" limits are for residential environments where TV and radio interference is more of a problem. Most personal computers are required to meet the class "B" limits since they are often sold for home use.
Sale of such equipment requires that the manufacturer receive a FCC CERTIFICATION letter and registration number. Larger mini-computers and networking equipment are only required to meet class "A" because they are sold for commercial use. Compliance with the FCC class "A" limit need only is verified by the equipment manufacturer.
http://www.fcc.gov
FCC Certified Top
A statement of compliance with U.S. FCC class "B" limits for radio frequency emission, which is issued by the FCC and accompanied by a FCC "registration" or "ID" number. Certified equipment must be marked with the ID number. Personal computer equipment marketed to the residential user must be FCC certified CLASS "B".
There is no way to confine the RF from the computer, printer, scanner, monitor, modem, cables, etc. It is a waste of time to even try. Turn the computer off when listening to your antique radios.
For radios which are not capable of using outdoor antennas, I purchase small ferrite chokes from Radio Shack. Short 1 to 1.5 inch ferrite sticks can be purchased with about two layers of wire on each. Wire two of them to the line cord on any radio--one per side of the line cord. Install .05 to .1 MFD condensers after and/or before these filters. Experimentation determines best placement of condensers. I find that after the chokes yields best results. Prior to chokes (plug side) often increases static for me. You can install a condenser across the radio side of the chokes and/or one on the plug side, or you can install two on the radio side and/or plug side, and connect their junction to the chassis (where the two meet). Filtering the line cord may reduce reception, as the line cord is the radio's ground in most cases. A separate ground may be necessary (radiator, for example...I have plenty of these at my disposal in my appartment. They heat well and make perfect grounds!). Grounding AC-DC radios isn't recommended, though you can try to through a .o5 to .1 MFD condenser. Hum will result if the plug is inserted the wrong way, and may result with it in either way with some radios.
You can also try installing the chokes and/or condensers on the computer line cord. Sometimes a .o5 to .1 MFD condenser is all that it takes. I installed a nice little .1 MFD 200 WVDC condenser on the dimmer unit for my under cabinet halogen lights. Used to be that the radio I have plugged into the same outlet was useless at all times when the lights were on at any brilliance. The simple addition of this small condenser across the line cord has made the radio a real performer on all local stations. More interference is present, of course, when the lights are operated at less than full brilliance.
Of course when do I really use that radio anymore? When do I use any of my radios? AM radio really does suck. When I have time this summer, I'm going to build my little 4 tube transmitter (3 #41 tubes and an 84/6Z4....the 3 #41s will serve as driver, oscillator, and class C RF amplifier). Then I'll have a use for my radios. Sometimes I am very tempted to build a small super regenerative FM circuit for all of my radios and then link this to the tuning mechanism via a cam or something. I could then write to the one AM station left that used to play really good big band on Saturdays and tell them that I've happily converted all of my radios to FM, and that I will never have to listen to their crappy station again. I wish I could convert all of my radios in a very good way without ruining their values. It'd be cool, say, if I had a lot of money (which I don't). I'd have new numbers printed on the dials in the same fonts as the old ones, and I'd reconfigure the circuitry so that the same tubes do a new trick (FM). That'd really be considered butchering, though. Best that I don't. I'd feel guilty doing that anyway. As much as I hate what is on AM now, I've always enjoyed that sound AM has. When you pull in all of those distant fading and drifting stations, it's a lot of fun. It's like listening to the living breathing U.S.A. or something. Short wave is a blast, too. When you listen to AM, you can almost go on a journey through the world. On FM all you get is a loud hiss between local stations (even with good radios). AM's frequency range isn't great for classical music, but it's always sounded fine with big band and Latin music. It's kind of fuzzy sounding, too, though quite acceptable. It's amazing how so many modern AM car radios chop the heck out of the listenable frequency range. Those radios, with all of their fidelity on FM, sound terrible on AM. Treble is gone on most modern AM radios. The old ones that we restore bring out all of the subtle beauty and richness that can be passed over AM. Most people think that AM is a lot worse sounding than it really is due to these poorly designed new radios.
....should say "or you can install two IN SERIES on the radio side and/or plug side, and connect their junction to the chassis (where the two meet)."
Steve,
Does the new PC have a wireless keyboard or mouse? If so you might try going back to a standard keyboard and mouse. As a general rule PCs don't generate a lot of RFI. I have an old National NC-109 positioned three feet from my homemade 1.9Ghz PC and I get absolutly no interferance. However, the electrostatic air cleaner eight feet away generates substantial interferance. As an aside, back way long ago when I was maintaining room filling main frame computers we had a program that we would run during preventive maintenance down time at the Christmas season. We would set a small transistor radio tuned off station on top of the processor cabinet. running the program would cause the radio to play Christmas carols.
Regarding computer interference, I am by no means an expert at all. However, in my very limited experience, aside from wireless internet, I have found that the majority of interference comes from power supplies and surge protectors. The surge protectors are an easy fix as they are often separate from the computer. Thank goodness my parents' finally shorted out. That thing was a real noise maker. Other power supplies that can creat AM noise for reasons that are unknown to me are cell phone chargers. Every now and then one will create a humming or other strange noise in one of my radios. It doesn't necessarily have to be in the same room as the radio.
As far as computers generating RFI, the only places where I find this so is when I'm at work (probably for reasons that Peter stated). Whenever I've brought one of my radios to work, it has always picked up the blurbing and rushing sounds of data going through the computers. I have no idea what systems were in use in these various places. Could have been easy for the radio to pick up all the interference, too, because most of these buildings were steel (poor radio reception leads to picking up of other things) Could have even had something wireless associated with some of the computers. Filtering the line cord of your radio may or may not help in this case. I have limited experience with experimentation with my radios while at work. I try not to. I also don't have the kind of job anymore that would allow me to bring in a radio.
Regarding my earlier suggestion for a filter on the line cord of a radio, if you find that a filter on both sides of the cord severely limits reception, and you don't have a convenient ground at your disposal, try filtering only one side (I have tried this with mild success, and did this in a location that had wireless internet). Plug the radio in so that the choked side is hot, and is preferrably not the side that goes to the switch on the volume control. You may connect a condenser on the radio side of the filter, from the filter to the cold side of the line cord. You may also try connecting a condenser from the cold side of the cord to the chassis if the radio is an AC type, and otherwise has no connection between the chassis and the line cord. If the radio is an AC-DC radio, it probably already has the chassis connected to the line cord through a condenser or directly. The best static elimination without detriment to reception is with a filter either on one or both sides of the line cord and with a wire from the chassis to a radiator pipe. Connecting a ground wire to the ground screw on your outlet may or may not introduce noise, depending upon what other noise producing devices are plugged into that circuit. The ground on the AC supply in your house is not necessarily a noise free one. Air registers can be, though they aren't always grounded, either. Water pipes and radiators are the best.
Also, I have had some luck with tuned filters. I have experimented with various sized coils (usually like the chokes that Radio Shack sells, or home made air coils wound on a 1/2 inch dowel...about 50 turns of wire or so) and condensers. Generally anything .1 MFD and less is well suited for RF supression. Anything over .1 MFD is just sucking extra power from the line cord. I have used very small mica condensers to remove some types of noises. With such tuned filters, however, you might not remove static from all parts of the dial, and you may receive a different kind of static on a different day. Still, if you don't mind probing around the AC cord while the set is running, trying out various condenser set-ups can be quite interesting. It's always a surprise when you slip and there's a huge spark and a bang. I've almost had a heart attack a few times from this.
Regarding programming, depends on the city you live in, I guess. Milwaukee just doesn't have anything anymore.
WOKY here in Milwaukee will give you your share of Neil Diamond, Barbara Streisand (sp?), Barry Manalow, and all those other easy listening reminiscing singers. They're cool and all, but their music REALLY gets old fast. They also play Frank 'n' Friends on Saturdays. I'm not a real fan of Frank, though. He was a good singer, but his lifestyle doesn't appeal to me, and I don't understand why he has so many die-hard fans when there are so many other artists that were just as good, but not just as harsh. The bad ones tend to stick in people's minds, I guess, and bad is cool or something.
Who knows...all I hear about him is rumor, anyway, so it isn't all necessarily true. Besides all of that, his music is WAY overplayed. There was so much beautiful music from the 1930s and 1940s, and it is all lost because it isn't bad and cool. Shame.
Oh well.
Steve,
Take your VOM and check for a difference of pontential between your computer cabinet and the radio chassis. If you don't have any volts there then connect a wire between one of the power supply mounting screws on the back of the PC's cabinet and the radio's chassis. If you have volts between the units then ground both of them solidly to the house ground at the same point. If you have volts don't connect a wire between them or you will create a ground loop and that ain't good.
Will
Steve,
Another suggestion: If you suspect the PC's power supply you could swap it with one from another of your PCs. They are all the same except for wattage capability. Usually they run 300, 350, or 400 watts. You can replace a 400 with a 300 for a short test. They are very easy to remove and replace. Three or four screws near the fan grille on the back of the cabinet, one or two plugs to the system board, and the plugs to your internal drives. The plugs to the board will have squeeze latches and all the plugs are unique to their sockets and you can't get them mixed up. You will find extra drive plugs and any of them will work if the plug fits the receptical. Perhaps your builder will loan you a supply to try. If he's like me he will have several good ones around. We're talking about transformerless switching power supplies here and they have lethal voltages inside so don't poke around in it with the power on. Also, the plug or plugs to the board will be a 20 pin and maybe a 4 pin. If your board uses the 4 pin and it isn't present on the replacement supply the PC will still run ok without for your test.
Will
Steve,
Your new PC will have a soft power down supply and there won't be any connection to the power button on the front of the cabinet. Power is controlled through the 20 pin plug from the system board. An older PC may not have this type of supply. If you see a supply with two single row plugs about 1 1/2 invches long it won't work in your new PC.
Will
Thomas,
It might. I just reasoned that it was an easy fix to try and couldn't hurt if there is no potential between them. In a large computer system all the cabinets were connected together with a seperate wire if they wern't physicly bolted together. RFI was especially troublesom to a magnetic character reader in a check sorter. I have actually 'scoped the signal from a local AM station on the frame of a sorter. Running a braided wire from the sorter frame to the sorter buffer cabinet fixed the trouble that it was causing. I think that Steve has a faulty switcher power supply in his new PC.
Will
Ask them if they will allow you some credit to exchange the case for a Class B case. they take back the old case and charge you the dif for a new one and maybe some sharing in the labor...
But it is rather EASY to do the whole thing yourself too.
You can find good reasonably priced units on the net... cheap... maybe 40-60 bucks I'm guessing or cheaper.
