Wire wound resistors should always be replaced with the same. They are an added expense to the manufacturer, and would not have been used unless the manufacturer felt it necessary.
http://www.goldmine-elec-products.com/products.asp?dept=1128
Be careful of the wire wound resistor in an RF circuit, where the wound wire can add additional inductance to the circuit. For audio, this may not be a problem, but for RF is can be. the best bet is to look at what type is used and replace with the same if there is any question. If the old resistor is a 1/2 watt, you can use a 1 or 2 watt to replace it - the 2 watt would be an over kill and additional cost, but it would run cooler then the others (in other words, its ok to go up in wattage size, but not down).
David S
:Hello, I am restoring a few 1940's radios and wanted to know what type of resistors to use. Antique electronic supply offers Carbon Film Resistors or Carbon Composition Resistors. Does it matter what type I use. Also there are some wire wound resistors in the zenith radios, what type do you replace them with.
:Thanks
:David
