A 50B5 runs hotter than most other tubes. It's not unusual to have some leakage between cathode & filament or even grid. As tubes have more use this leakage increases.
Does your tester have a neon lamp to show shorts? If the short lamp is only dim may not make a difference on a 50B5.
Since you bought NOS, number and brand marking should be easy to read. If they are missing tube may not be NOS?
In most radios you shouldn't need to be replace many tubes. Did you buy the radio from someone who just filled empty sockets with tubes?
:Hi All!
: I'm working on a Philco Model 46-420, I had a bad 50B5 along with some other tubes that needed replacing as well, I have gone completely through the radio, recapped etc... replaced all tubes as needed, the problem I have is both so called NOS 50B5's that I have bought have shown either shorts and or grid leakage on my tube tester, I can not fault the tester, for I have tested many many other tubes on this tester and it is accurate, my question is , was there an inherit problem with this particular tube, for I have yet too get a good one?
:Mark
Mark, I have several used 50B5's that I have no use for and would be happy to send you. They test good but the neon short indicator bulb on my tester is out. If you want them, email me your address. Regards,
Jon
Mark D. Moore
5404 S. 95th CT. #302
Omaha, NE 68127
Thanks Again Jon!
Mark
I will get them in the mail this weekend. Hope they work for you.
Jon.
