By the way, among my repair options: 1) With a lot of work, I could reverse this RF output wafer with the identical RF input wafer, which is not loaded with B+; 2) or I could put a couple of .1 uF ceramic capacitors to the wipers on the other side of the affected wafer to DC isolate it (unless the arc-track grows so far that it reaches the grounded shaft!), this side goes to the mixer input and will slightly skew the tracking; 3) or I could capacitively couple the finicky 6SG7 RF amp output to the bad bandswitch and alter it to get B+ through a new resistor; or 4) wait around till a replacement wafer turns up somehow, or a junk S-40.
The bad wafer has a burned black spot on the center-disc portion, and 7 M ohms resistance between the 2 wipers on the opposite sides, but no visible black on the outer phenolic ring that carries the stationary contacts. The arc-track seems established now so that it will arc as soon as you power it up. Other suggestions? And is there a rule anywhere that you have to let contact cleaner dry before powering up the set? Did the cleaner just "activate" some grime and let an arc-track develope?
:Before aligning a Hallicrafters S-40, I used Caig Deoxit R5 to clean the very touchy bandswitch. No more intermittent contact - but "crackling static" immediately increased (I hadn't noticed much static before the cleaning) - but probably due to B+ beginning to find a path across the phenolic bandswitch wafer which switches transformer primaries on the RF amplifier plate, because within a few minutes, it started arcing on that wafer, and now arcs and starts a tiny fire every time you power it up. This wafer carries nearly 300 V. Has anyone had the direct experience of a bandswitch phenolic wafer failing this way (leaking high voltage / arcing a track into the phenolic) right after applying Caig, or any other contact cleaner? I don't recall any warnings - so I was hesitant to believe it was related, but sure is a coincidence the phenolic would track and arc and burn after 50 years as soon as I applied a cleaner.
:By the way, among my repair options: 1) With a lot of work, I could reverse this RF output wafer with the identical RF input wafer, which is not loaded with B+; 2) or I could put a couple of .1 uF ceramic capacitors to the wipers on the other side of the affected wafer to DC isolate it (unless the arc-track grows so far that it reaches the grounded shaft!), this side goes to the mixer input and will slightly skew the tracking; 3) or I could capacitively couple the finicky 6SG7 RF amp output to the bad bandswitch and alter it to get B+ through a new resistor; or 4) wait around till a replacement wafer turns up somehow, or a junk S-40.
:The bad wafer has a burned black spot on the center-disc portion, and 7 M ohms resistance between the 2 wipers on the opposite sides, but no visible black on the outer phenolic ring that carries the stationary contacts. The arc-track seems established now so that it will arc as soon as you power it up. Other suggestions? And is there a rule anywhere that you have to let contact cleaner dry before powering up the set? Did the cleaner just "activate" some grime and let an arc-track develope?
If I all-out clean a switch, I unwire it from the set. Then I take a toothbrush and some mineral spirits and clean away all of the gunk. Then I take the same toothbrush and some dish or laundry detergent and scrub in hot water. Then I let it dry for a day or so....you can dry in sunlight if you wish. If you wish to have bright contacts, you can polish them with brasso before washing in soap and water.
