Grunow 1193 chassis type 11G schematic
4/14/2006 10:34:23 PMDavid
Hello, I need a schematic for this radio. I want to recap it, but there are no values on the capacitors, they only have part numbers.
David
4/14/2006 11:57:29 PMMAG
Here is a schematic that may be similar, for model 1183, chassis 11H. You might be able to use the part numbers there to identify your unknown capacitors.
http://www.nostalgiaair.org/PagesByModel/340/M0008340.pdf
Meade
:Hello, I need a schematic for this radio. I want to recap it, but there are no values on the capacitors, they only have part numbers.
:Thanks
:David
4/15/2006 4:40:27 PMDavid
Hello, the tube line up is diffrent. Plus when you zoom in you can't read the numbers. I have 3 6K7G, 1 6A7G, 1 5Z3, 2 6F6G, 2 6C5G and 1 6H6G. There are also three can capacitors with no numbers.
David
