Green, it's described as, Medium-Short Persistence and used in oscilloscopes.
: DOES ANYONE KNOW WHAT COLOR, A CRT WITH P-31 PHOSPHER,
: DISPLAYS TO THE EYE.?...THANK YOU....ELMER
: Green, it's described as, Medium-Short Persistence and used in oscilloscopes.
: Norm
: : DOES ANYONE KNOW WHAT COLOR, A CRT WITH P-31 PHOSPHER,
: : DISPLAYS TO THE EYE.?...THANK YOU....ELMER
P31 was the standard phospher used in nearly every Tektronix
oscilloscope of the 1970s - 1990s unless a special option was
ordered (usually for a hot-to-the-scope-camera P11 I think
it was, expecially in 7904s). So anytime you see a standard
7000-series, 5000-series or 400-series portable, you'll be
seeing a P31. Oh, but the color will be off a little bit on
most Tek scopes because a blue filter is installed as standard
equipment to help with contrast.
Of course, in this day of DSOs, the high-speed CRT is nearly
gone, replaced by full-color, computer-controlled CRT or LCD
displays.
Dean (a former Tek tech)
