Here's one that looks interesting. It uses two 50C5 tubes, which may make it a bit more powerful. I don't know. I would like to try building one. The coil is the four lug two separate coil type. www.tubesandmore.com sells slug tuned coils, but they are usually the 3 lug type where the two coils are connected together to one of the lugs. You can still make this kind of coil work. Connect the lug where the two join to B- as shown in the schematic. The small coil end will go to the grid through the appropriate condenser shown in the schematic. The large coil will still have a condenser bridged across it. Instead of connecting directly to the plate, you'd use a .0001 MFD condenser to connect it to the plate.
I should try building this for myself. It may be very interesting to use.
I recenly bought a transistor AM transmitter kit for only 99 bucks and they also have a 35 dollar model.
I bought it from www.Ramseykits.com
I haven't built it yet... but it is here.. lol.
Here are the links for that transistor model.
And.. listed further below that I've included a couple of links and a schematic for that very poular Knight Kit 50C5 transmitter that was available in the 50s. There is also a wonderful story there too about a guy from "AM Daytime" KHGL radio that has used this little 100mw transmitter for over 20 years!!
Transistor Transmitter kit:
$99.00 model:
http://www.ramseyelectronics.com/cgi-bin/commerce.exe?preadd=action&key=AM25
$35.00 Model:
http://www.ramseyelectronics.com/cgi-bin/commerce.exe?preadd=action&key=AM1C
Tube Transmitter:
Knight Kit 50c5 transmitter schematic and info:
http://www.smecc.org/knight_kit_home_broadcasters_-_allied_electronics.htm
http://www.smecc.org/wpe_files/wpe1C1.gif
http://www.knightkit.com/knight_articles/shiningknight.htm
http://www.smecc.org/broadcasting_from_the_home!.htm
Just feed your CD player output into the audio input and tune the RF output to a quiet spot on your AM dial and place the output of the signal generator near to your radio antenna and VOILA!!!
http://antiqueradios.com/forums/Forum13/HTML/004443.html
