Zenith 6D2615 recap
3/25/2006 10:38:50 PMHutchclub
I'am working on a Zenith 6D2615. I have recapped but for the C14 and C15 and I am at a loss, as to the polarity of these caps. I think they are negative to the field speaker. Please advise if I am correct.
Thanks for all your help.
3/26/2006 12:12:40 AMThomas Dermody
If you're talking about the Zenith 6D615 (not sure if that 2 is supposed to be in there), the field coil is positive. When looking at the schematic, where the condensers join up and to the left (upper left hand corner of box formed by their connections) is B-. C15 connects to the cathode of the rectifier, which is the most positive item in the radio. C14 connects after the field, which is slightly less positive than the rectifier cathode, but certainly much more positive than B-. The field coil is part of the B+ circuit.
I suggest that if this radio still has its G style tubes in place (35Z5G and 35L6G), that you leave them in the radio unless they have severe defects (weak operation, or otherwise burned out). They are rare, and make the back of the radio look exceptionally nice.
3/26/2006 9:02:00 PMhutchclub
:If you're talking about the Zenith 6D615 (not sure if that 2 is supposed to be in there), the field coil is positive. When looking at the schematic, where the condensers join up and to the left (upper left hand corner of box formed by their connections) is B-. C15 connects to the cathode of the rectifier, which is the most positive item in the radio. C14 connects after the field, which is slightly less positive than the rectifier cathode, but certainly much more positive than B-. The field coil is part of the B+ circuit.
:I suggest that if this radio still has its G style tubes in place (35Z5G and 35L6G), that you leave them in the radio unless they have severe defects (weak operation, or otherwise burned out). They are rare, and make the back of the radio look exceptionally nice.
:Thomas
3/26/2006 9:02:16 PMhutchclub
::If you're talking about the Zenith 6D615 (not sure if that 2 is supposed to be in there), the field coil is positive. When looking at the schematic, where the condensers join up and to the left (upper left hand corner of box formed by their connections) is B-. C15 connects to the cathode of the rectifier, which is the most positive item in the radio. C14 connects after the field, which is slightly less positive than the rectifier cathode, but certainly much more positive than B-. The field coil is part of the B+ circuit.
::I suggest that if this radio still has its G style tubes in place (35Z5G and 35L6G), that you leave them in the radio unless they have severe defects (weak operation, or otherwise burned out). They are rare, and make the back of the radio look exceptionally nice.
::Thomas
3/26/2006 9:19:42 PMhutchclub
Thanks for the help Thomas!
Now I see the positive side. The tubes are 35Z5GT and 35L6GT. This radio plays very nice and looks good too!
Your quick response is greatly appreciated.
:::If you're talking about the Zenith 6D615 (not sure if that 2 is supposed to be in there), the field coil is positive. When looking at the schematic, where the condensers join up and to the left (upper left hand corner of box formed by their connections) is B-. C15 connects to the cathode of the rectifier, which is the most positive item in the radio. C14 connects after the field, which is slightly less positive than the rectifier cathode, but certainly much more positive than B-. The field coil is part of the B+ circuit.
:::I suggest that if this radio still has its G style tubes in place (35Z5G and 35L6G), that you leave them in the radio unless they have severe defects (weak operation, or otherwise burned out). They are rare, and make the back of the radio look exceptionally nice.
:::Thomas
3/27/2006 12:32:18 AMThomas Dermody
The schematic is a little confusing. Lots of wiring going on there. It's hard at first to even determine which wire is the B- wire. This tends to be the case with Zeniths, though. With all of those extra parts that make the set perform so much more nicely, the schematic tends to get a bit cluttered. The quality really does go in before the name goes on, though.
