speaker plug
3/23/2006 9:57:32 PMAl
Hi: I have an old RCA 103 speaker (battery style) that is missing its metal ends. They connect to the chassis and are similar to speaker jacks but smaller in length and diameter. Any suggestions or place that sells something that can be used as a replacement or substitute? Thanks. Al
3/24/2006 10:55:36 AMGreg
Hi Al, Antique Electronic Supply used to carry them. I had bought some a few years ago from them.
Greg
:Hi: I have an old RCA 103 speaker (battery style) that is missing its metal ends. They connect to the chassis and are similar to speaker jacks but smaller in length and diameter. Any suggestions or place that sells something that can be used as a replacement or substitute? Thanks. Al
3/24/2006 2:19:49 PMAl
:Thanks Greg. I saw they had several types listed. I'll contact them to see if any might work. Al.
:Greg
::Hi: I have an old RCA 103 speaker (battery style) that is missing its metal ends. They connect to the chassis and are similar to speaker jacks but smaller in length and diameter. Any suggestions or place that sells something that can be used as a replacement or substitute? Thanks. Al
3/24/2006 8:26:47 PMDoug Criner
Are these the little individual plugs for each speaker conductor? Try RadioDaze SPC-TIP.
3/26/2006 10:55:31 PMAl
Yes. I checked their webpage and seach engine but couldn't find them. Sent an e-mail to see if they had something. Thanks. Al
:Are these the little individual plugs for each speaker conductor? Try RadioDaze SPC-TIP.
3/27/2006 11:49:09 AMDoug Criner
Al, I just checked the RadioDaze website and couldn't locate the speaker/headphone tips either. They list them in their printed catalog, p. 28, cat. no. SPC-TIP, 5 for $3.00.
AES www.tubesandmore.com also has them. Phone tip, S-H33-156, 10 for $6.50.
3/27/2006 4:53:35 PMAl
Doug: Perfect. Thank you. Al
:Al, I just checked the RadioDaze website and couldn't locate the speaker/headphone tips either. They list them in their printed catalog, p. 28, cat. no. SPC-TIP, 5 for $3.00.
:AES www.tubesandmore.com also has them. Phone tip, S-H33-156, 10 for $6.50.
