Heathkit battery eliminator voltage problem-Zenith farm radio
3/17/2006 9:10:35 PMDavid
Hello, I recently got a Heatkit BE-3 battery eliminator. It is rated for 6 volts 10 amps. The volt meter goes from 1-15v and the amp meter goes from 1-15a. My question is that when I first powered it up from sitting for many years it was only reading 4 volts and after leaving it on for about an hour it is now reading 10.5 volts without a load. When I hook up my Zenith 6 volt battery radio to the battery eliminator the voltage drops to about 3.5 volts with about 1.5 amps. The zenith is a 4-b-131 and works on 6 volts and draws 1.7 amps. Why is the voltage droping so much, I have the voltage knob turned all the way up. Is it possible that the electritic capacitor needs to be reformed or is no longer any good? There are no other parts that look like they could go bad, how do I increase the voltage with a load on my battery eliminator.
David
3/17/2006 11:22:01 PMRich, W3HWJ
It is possible that the electrolytic caps are bad after so many years. I wouldn't bother trying to re-form them. You can buy caps fairly cheaply. Another real possibility is that the Selenium Rectifiers are shot. Selenium ages and the forward drop goes up over time. I would put in some new capacitors and replace the selenium with a full-wave silicon diode bridge. Modules rated at about 200 Volts and 25 amps should be fine for this, if you mount the module on heatsink. I am not sure if the Heathkit had a cooling fan to cool the rectifier stacks (these look like metal fins). A cooling fan would be beneficial when running at high current. Also, when you replace selenium with silicon, the output voltage may rise and even go above 15 volts. You may need to insert a resistor of less than an ohm to reduce surge current when the caps charge at start-up. Don't bother looking for replacement selenium rectifiers. They are still made in India, but not here.
Good luck. Rich
:Hello, I recently got a Heatkit BE-3 battery eliminator. It is rated for 6 volts 10 amps. The volt meter goes from 1-15v and the amp meter goes from 1-15a. My question is that when I first powered it up from sitting for many years it was only reading 4 volts and after leaving it on for about an hour it is now reading 10.5 volts without a load. When I hook up my Zenith 6 volt battery radio to the battery eliminator the voltage drops to about 3.5 volts with about 1.5 amps. The zenith is a 4-b-131 and works on 6 volts and draws 1.7 amps. Why is the voltage droping so much, I have the voltage knob turned all the way up. Is it possible that the electritic capacitor needs to be reformed or is no longer any good? There are no other parts that look like they could go bad, how do I increase the voltage with a load on my battery eliminator.
:Thanks
:David
3/17/2006 11:49:50 PMEdd
Considering the BE-3 to be the same order of design as its upgrade , the BE-4….refer to :
http://web.archive.org/web/20040127103557/www.triplanetary.freeserve.co.uk/diagrams/be-4.gif
It would seem logical that old warhorse was deficient in its filtering capacity with the type of electrolytics available on those days.
Am I correct that there is a marking of a the selector switch of 12 Volt operation of the supply at a like reduced current capability also ?
The other unknown thing is if the unit was using silicon diodes for the power rectifiers or was the unit of such age that it was using old large plate selenium rectifiers ?
The only thing that I could suggest would be to advantage in upgrading would be the replacement of the old obviously deficient electrolytics with some of the modern computer grade electrolytics, even if of newer surplus stock.
( And no, I wouldn’t expect a successful reforming action of your old units….as that is more successful on high voltage electrolytics.)
The second thought would only be if the unit was originally utilizing large plate selenium rectifier stacks and that would be to replace them with solid state diodes, and more specifically, Schottky diodes as used in modern switchmode power supply designs.
Up date me on what is inside the BE-3….also look for some code dates on parts to see how old that unit is.
73’s de Edd
:Thanks
:David
3/18/2006 12:10:26 AMdavid
Try this schematic--http://www.vintage-radio.info/heathkit/diagrams/be-4.gif. The model that I have is only a 6-volt model and does have a very large sellinum rectifer in it.
David
3/18/2006 12:50:15 AMMark
Just a word of caution. Do not use your old radio as a test load for the defective power supply. It could go up in smoke. Get your self some load resistors. 6 ohm will give you 1 amp draw at 6 volts. Make it a 10 watt resistor (6 watt + safety margin). With the power supply loaded, check the raw B+ voltage being applied to the regulator circuit to see if it is high enough. That would be a good place to start.
MRO
3/18/2006 11:30:13 AMRich, W3HWJ
The Heathkit eliminator was made in the early 50s. Silicon diodes didn't become available until the late 50s, so selenium was the usual rectifier used. Schottky diodes may be good replacements, but I would use high voltage Schottky's, at least 50 volt rating. Schottkys will run cooler, but will also give you more output voltage than you are expecting. Schottky's are a bit more vulnerable to over-voltage "spikes" that can occur when connecting or disconnecting a load with the voltage applied. Also, never touch the output leads together to see if you get a spark.... you could zap the rectifier. The old selenium units could tolerate that, but silicon or Schottky may be harmed. Rich
:Try this schematic--http://www.vintage-radio.info/heathkit/diagrams/be-4.gif. The model that I have is only a 6-volt model and does have a very large sellinum rectifer in it.
:Thanks
:David
3/19/2006 6:40:09 AMEdd
"sellinum"....."SELLINUM".......I always thought that it was silly-inny-yum-yum.
I have an update posted at:
http://www.nostalgiaair.org/Forums/Messages/920/M0037920.htm
:Thanks
:David
3/19/2006 1:57:32 PMThomas Dermody
They still use selenium rectifiers in modern battery chargers. Both of my parents' battery chargers are about 20 years old and the rectifiers still work perfectly. They use them all the time. My sister has one that's from about 1999, and it has a 20 ampere selenium rectifier. It works quite well, too.
First replace electrolytics and test selenium rectifiers. They shouldn't allow any reverse current of any kind. If you use your meter's X10,000 ohm scale and you get leakage even in the millions of ohms, then the rectifiers are bad. Replace them. If they don't have reverse leakage, though, try them out with the new electrolytics. If current is still low, then the units are faulty (even if they don't have reverse leakage..they do deteriorate on occasion, especially if subjected to moisture). If the unit puts out adequate power, though, leave the original rectifiers alone. They can take shorts and surges and all sorts of stuff, and they last a fairly long time. They cool themselves naturally--due to all the fins. Place a fuse on the output of the power supply that is rated for the power supply's maximum output. This will prevent damage in the event of a short (say your vibrator sticks). Place a fuse on the radio that's rated at 1 or 2 amperes above the radio's normal operating current, to protect the radio as well.
3/19/2006 2:42:23 PMeasyrider8
Testing a Selenium with a ohmeter is meaningless, they have to be tested with a load on them, they do not form the junction without a load, they are not like silicon diodes. The best way to test ones this size is with a 12 volt battery, and a 12 volt bulb which draws at least 2 amps, a car headlite would work fine. Put the bulb in series with the selenium and connect to the battery, now reverse the connections at the battery. One way the bulb should light, reverse the connection and it should not. If the bulb stays lit in both directions or if it doesn't light the seleniun is bad. Each section of the selenium should be checked like this.
3/19/2006 3:29:27 PMRich, W3HWJ
Didn't know that new chargers still used selenium. I recently wrote an article about this for Electric Radio (to be published soon) and found a company in India still making selenium stacks. I guess that most chargers are now made in China or Taiwan and may still make selenium devices there. Due to EPA issues, selenium is difficult to process in the USA. Selenium should last 20 yrs, but a Heathkit from the early 50s is already over 50 yrs. Reverse ohm-meter reading may not tell you much. Selenium has a higher leakage level than silicon and at 6 or 12 volts, leakage isn't a major issue. The biggest problem is that the forward loss increases with aging. This will prevent you from getting full rated current. As you increas the load, the voltage will just drop off.
Rich
:They still use selenium rectifiers in modern battery chargers. Both of my parents' battery chargers are about 20 years old and the rectifiers still work perfectly. They use them all the time. My sister has one that's from about 1999, and it has a 20 ampere selenium rectifier. It works quite well, too.
:First replace electrolytics and test selenium rectifiers. They shouldn't allow any reverse current of any kind. If you use your meter's X10,000 ohm scale and you get leakage even in the millions of ohms, then the rectifiers are bad. Replace them. If they don't have reverse leakage, though, try them out with the new electrolytics. If current is still low, then the units are faulty (even if they don't have reverse leakage..they do deteriorate on occasion, especially if subjected to moisture). If the unit puts out adequate power, though, leave the original rectifiers alone. They can take shorts and surges and all sorts of stuff, and they last a fairly long time. They cool themselves naturally--due to all the fins. Place a fuse on the output of the power supply that is rated for the power supply's maximum output. This will prevent damage in the event of a short (say your vibrator sticks). Place a fuse on the radio that's rated at 1 or 2 amperes above the radio's normal operating current, to protect the radio as well.
:Thomas
3/19/2006 11:29:29 PMDavid
Hello, thanks for all the great information. There is only one capacitor rated 10000uf 10 volts. any idea where to find one this large?
David
3/20/2006 9:02:55 AMMark
Do you have any electronic surplus stores in your town? Quite often you can find an old computer power supply with salvagable parts. Also you can parallel several smaller value capacitors to get the rating you desire ie: 5 paralleled 2200 uf capacitors ( a common value) will get you 11000 uf.
MRO
3/20/2006 11:06:32 AMRadiodoc
Hi Rich,
Selenium rectifiers are still alive and well at least at one place in the US of A. For kicks check out http://www.cougarelectronics.com/index.html
:Didn't know that new chargers still used selenium. I recently wrote an article about this for Electric Radio (to be published soon) and found a company in India still making selenium stacks. I guess that most chargers are now made in China or Taiwan and may still make selenium devices there. Due to EPA issues, selenium is difficult to process in the USA. Selenium should last 20 yrs, but a Heathkit from the early 50s is already over 50 yrs. Reverse ohm-meter reading may not tell you much. Selenium has a higher leakage level than silicon and at 6 or 12 volts, leakage isn't a major issue. The biggest problem is that the forward loss increases with aging. This will prevent you from getting full rated current. As you increas the load, the voltage will just drop off.
:Rich
::They still use selenium rectifiers in modern battery chargers. Both of my parents' battery chargers are about 20 years old and the rectifiers still work perfectly. They use them all the time. My sister has one that's from about 1999, and it has a 20 ampere selenium rectifier. It works quite well, too.
::First replace electrolytics and test selenium rectifiers. They shouldn't allow any reverse current of any kind. If you use your meter's X10,000 ohm scale and you get leakage even in the millions of ohms, then the rectifiers are bad. Replace them. If they don't have reverse leakage, though, try them out with the new electrolytics. If current is still low, then the units are faulty (even if they don't have reverse leakage..they do deteriorate on occasion, especially if subjected to moisture). If the unit puts out adequate power, though, leave the original rectifiers alone. They can take shorts and surges and all sorts of stuff, and they last a fairly long time. They cool themselves naturally--due to all the fins. Place a fuse on the output of the power supply that is rated for the power supply's maximum output. This will prevent damage in the event of a short (say your vibrator sticks). Place a fuse on the radio that's rated at 1 or 2 amperes above the radio's normal operating current, to protect the radio as well.
::Thomas
3/20/2006 11:19:24 AMeasyrider8
Rich
Many selenium devices are still being made in this country and we are a large producer of selenium. They are the ideal choice for welders, battery chargers, plating power supplies, or anyplace a heavy duty rectifier is required, they can be direct short circuited for short periods of time with no damage. They also exhibit a slow start due to the fact the junction has is reformed for each use, they do not produce the RFI that silicon does and are not susceptible to powerline surges. I have not seen any evidence that they age although there are many stories to that effect. They are the ideal rectifier, too bad they are no longer commonly used radios due to manufacturing costs. If you care to email me I can send some data on selenium.
:Rich
3/20/2006 11:33:36 AMRich, W3HWJ
Dave,
I heard those same positive points back in the late 60s when I was at Westinghouse Semiconductor. We were still making selenium and some folks wanted to continue. There are reasons why virtually no modern electronics use selenium: efficiency, size, toxicitiy. They were great in old battery chargers because you could rub the clips together and get a spark to tell if the charger was ON. I still doubt that anyone is making selenium rectifiers in the USA; importing, maybe. Selenium is a rugged rectifier, but once you have one fail under load, it's an unforgettable experience! I can buy a 1 amp / 400 V silicon diode (1N4004) for a dime... what's an equivalent selenium going to cost? I can suppress the diode switching noise (if that's a problem) for another dime. Selenium is not hermetically encapsulated, so the environment (moisture and air) cause it to age. Sorry, you can't sell me. Rich
:Rich
:Many selenium devices are still being made in this country and we are a large producer of selenium. They are the ideal choice for welders, battery chargers, plating power supplies, or anyplace a heavy duty rectifier is required, they can be direct short circuited for short periods of time with no damage. They also exhibit a slow start due to the fact the junction has is reformed for each use, they do not produce the RFI that silicon does and are not susceptible to powerline surges. I have not seen any evidence that they age although there are many stories to that effect. They are the ideal rectifier, too bad they are no longer commonly used radios due to manufacturing costs. If you care to email me I can send some data on selenium.
:Dave
::Didn't know that new chargers still used selenium. I recently wrote an article about this for Electric Radio (to be published soon) and found a company in India still making selenium stacks. I guess that most chargers are now made in China or Taiwan and may still make selenium devices there. Due to EPA issues, selenium is difficult to process in the USA. Selenium should last 20 yrs, but a Heathkit from the early 50s is already over 50 yrs. Reverse ohm-meter reading may not tell you much. Selenium has a higher leakage level than silicon and at 6 or 12 volts, leakage isn't a major issue. The biggest problem is that the forward loss increases with aging. This will prevent you from getting full rated current. As you increas the load, the voltage will just drop off.
::Rich
3/20/2006 12:36:38 PMThomas Dermody
Well, then you have to read his data sheets, which are up-to-date, and show selenium devices still being produced in this country. It also does tell of how selenium is toxic in large amounts, or when it is vaporized (like when you fry a rectifier). They are great devices, though, and I always short my battery charger clips together to see whether it's on or not. It's also fun to see the sparks.
Selenium is also used for many other things like coloring and decoloring glass (this is amazing). Selenium is the bi-product of copper production, and is constantly being produced in this country.
3/20/2006 1:47:12 PMeasyrider8
This is very interesting and goes to show how myths are perpetuated. He we have an example of someone who wrote an article for a magazine which will be read by millions, I have to wonder how accurate the article was, and how extensive the research was. From the response there must be very little accuracy and no research. Most articles I have seen on selenium rectifiers should be considered fiction. Sorry about the rant but just because something is published does not mean it is true.
:Well, then you have to read his data sheets, which are up-to-date, and show selenium devices still being produced in this country. It also does tell of how selenium is toxic in large amounts, or when it is vaporized (like when you fry a rectifier). They are great devices, though, and I always short my battery charger clips together to see whether it's on or not. It's also fun to see the sparks.
:Selenium is also used for many other things like coloring and decoloring glass (this is amazing). Selenium is the bi-product of copper production, and is constantly being produced in this country.
:Thomas
3/20/2006 2:48:31 PMThomas Dermody
Are you talking about your article or another article?
When I read articles, though, I, too, cratique them. I used to believe that when it is written in a book, it is fact, like most other people. I have since found, though, that there are a lot of people out there writing books, who have no idea what they are talking about. Take, for instance, anyone who writes about Chevrolet 216.5 engines, or Chiltons manuals. Often the information I find about my engine is based on assumptions and myths (I am also amazed at how many people out there believe that my engine lasts forever...."they don't build them like they used to." Thank God!). If you ever read a Chilton's manual, it will most likely leave you more confused than you were before you read the manual.
I have several books from the 1960s which explain how to repair old radios. It is no wonder that so many people have come to believe that tube equipment is inferior. Nowhere in any of these manuals does it mention anything about capacitor leakage (which causes a TON of radio trouble I come across). They only talk about replacing tubes and broken wires and volume controls, ...perhaps drifted resistors. Still, since these books were published by big companies, many probably took all of the information as fact. Who knows, though. Since AM radios were used a whole lot more back then, maybe tubes did burn out more often. All I can say is that it is VERY rare for any of my tubes to burn out. I use my Silvertone phonograph almost daily, sometimes for several hours at a time, and yet the 1940 tubes are all still going strong (save the eye tube which I replaced because it was dim).
3/20/2006 4:04:48 PMGreg Bilodeau
Thomas, you mentioned something that made me think, I have been playing with old radios and tubes since about 1978. I have lots of radios and tubes and I do listen to them alot. I have one on my desk at work that I listen to every day, 9 hours a day. In all of these years I have only ever have one tube burn out, an RCA 280 Globe, turned my little Deforest Crosley floor model on and saw this flash from the back and that was the end of the 280. One tube in 28 years, thats pretty good. I have lots of tubes with date stamps on them from the early thirties and they still test and work like new.
Greg
:Are you talking about your article or another article?
:When I read articles, though, I, too, cratique them. I used to believe that when it is written in a book, it is fact, like most other people. I have since found, though, that there are a lot of people out there writing books, who have no idea what they are talking about. Take, for instance, anyone who writes about Chevrolet 216.5 engines, or Chiltons manuals. Often the information I find about my engine is based on assumptions and myths (I am also amazed at how many people out there believe that my engine lasts forever...."they don't build them like they used to." Thank God!). If you ever read a Chilton's manual, it will most likely leave you more confused than you were before you read the manual.
:I have several books from the 1960s which explain how to repair old radios. It is no wonder that so many people have come to believe that tube equipment is inferior. Nowhere in any of these manuals does it mention anything about capacitor leakage (which causes a TON of radio trouble I come across). They only talk about replacing tubes and broken wires and volume controls, ...perhaps drifted resistors. Still, since these books were published by big companies, many probably took all of the information as fact. Who knows, though. Since AM radios were used a whole lot more back then, maybe tubes did burn out more often. All I can say is that it is VERY rare for any of my tubes to burn out. I use my Silvertone phonograph almost daily, sometimes for several hours at a time, and yet the 1940 tubes are all still going strong (save the eye tube which I replaced because it was dim).
:Thomas
3/20/2006 11:36:00 PMRich, W3HWJ
Dave:
I sure wish Electric Radio were read by millions, but it's like to be a couple of thousand.
By the way, do you actually make selenium rectifiers in the USA? How much does a selenium unit cost that would replace a 10 cent silicon diode?
Rich
:Thomas
:This is very interesting and goes to show how myths are perpetuated. He we have an example of someone who wrote an article for a magazine which will be read by millions, I have to wonder how accurate the article was, and how extensive the research was. From the response there must be very little accuracy and no research. Most articles I have seen on selenium rectifiers should be considered fiction. Sorry about the rant but just because something is published does not mean it is true.
:Dave
::Well, then you have to read his data sheets, which are up-to-date, and show selenium devices still being produced in this country. It also does tell of how selenium is toxic in large amounts, or when it is vaporized (like when you fry a rectifier). They are great devices, though, and I always short my battery charger clips together to see whether it's on or not. It's also fun to see the sparks.
::Selenium is also used for many other things like coloring and decoloring glass (this is amazing). Selenium is the bi-product of copper production, and is constantly being produced in this country.
::Thomas
3/21/2006 4:14:12 PMEdd
On the cap:
Now unless your supplied schematic as well as the one I referenced is in error?????? Or you merely made a perfunctory glance at the mere presence of one metal canned unit. Instead kick your vision into “eagle eye mode” and check the bottom of that capacitor and see if you don’t detect the presence of 2 terminals instead of one, there by making that unit a dual section vice a single unit….as ground referenced to the metal can proper.
I supplied a fresh sourcing on an adjunct separate thread on your charger unit.
….you might not have seen it. At only 79 cents a copy with plenty of voltage rating headrooom:
4700 ufd 35 VDC:
:http://www.bgmicro.com/prodinfo.asp?sid=016883101851851924119644&prodid=CAP1068&page=1&cri=1068&stype=3
Multiple parallel units hold up better in the ESR perspective….. but they are really not being taxed in this application.
73’s de Edd
:Dave:
:I sure wish Electric Radio were read by millions, but it's like to be a couple of thousand.
:By the way, do you actually make selenium rectifiers in the USA? How much does a selenium unit cost that would replace a 10 cent silicon diode?
:Rich
::Thomas
::This is very interesting and goes to show how myths are perpetuated. He we have an example of someone who wrote an article for a magazine which will be read by millions, I have to wonder how accurate the article was, and how extensive the research was. From the response there must be very little accuracy and no research. Most articles I have seen on selenium rectifiers should be considered fiction. Sorry about the rant but just because something is published does not mean it is true.
::Dave
:::Well, then you have to read his data sheets, which are up-to-date, and show selenium devices still being produced in this country. It also does tell of how selenium is toxic in large amounts, or when it is vaporized (like when you fry a rectifier). They are great devices, though, and I always short my battery charger clips together to see whether it's on or not. It's also fun to see the sparks.
:::Selenium is also used for many other things like coloring and decoloring glass (this is amazing). Selenium is the bi-product of copper production, and is constantly being produced in this country.
:::Thomas
3/20/2006 12:31:31 PMThomas Dermody
Well, whenever I test a selenium rectifier in a radio (I've never tested them in a battery charger), I use my multi-meter. In any radio which I have owned which had excessive hum that couldn't be eliminated by replacing the electrolytics, I took out the rectifier and tested it with my meter. Whenever this problem existed, the rectifier had leakage in the reverse direction. Replacing the rectifier cured the problem. Normally when I test good selenium rectifiers, they have infinite reverse resistance. I don't see why using your ohm meter isn't helpful, since an ohm meter can sense leakage even in the millions of ohms (and all of my good seleniums have infinite resistance). I can see how using a voltage higher than your meter's would be helpful, since a higher voltage can jump leaks more than a low voltage can. Also, the leakage that will cause excessive hum in a radio isn't normally the kind of leakage that will light a lightbulb (unless the rectifier has a dead short). If you want to do high voltage checks, perhaps connect the rectifier to a high voltage direct current source (say 120 volts DC, as seleniums are often found in AC-DC receivers). Then see if current will flow backwards through the rectifier by testing with your meter. It takes very little reverse leakage, though, to upset a radio. The small amount it takes to upset a radio may not be enough to light a lightbulb.
Now, the rectifier in question in this thread is for a low voltage source, not a B rectifier in a radio. Here it may make sense to test with a small lightbulb. I still think that meter testing is also advisable, as a very small reverse current can slowly damage an electrolytic, and yet it may not be able to light a lightbulb.
