:The #47 tube (audio driver) in my Philco 70 gives off a blue light on one side. I tested it for gas on my Hickok 534 and it was negative. I put in a NOS 47, and it also had a tiny tinch of blue on one side (it also tested negative for gas). I recapped everything except the tiny value molded caps. The resistors tested within tolerance. Is the blue glow to be expected, or should I look for a problem that doesn't involve caps or resistors???
:As always, thanks in advance for your help!
:Jeff S.
Mmmm...Philco 70...(pause....Droooool...wipe off drool...continue !)
:Not a rarity at all on the higher beam currents experienced on power tubes. Typically coinciding with a manufactured rectangular divot
:opening in the plates side superstructure. Typically in about the same blue color spectrum as you would see on a propane torch or blue
:natural gas flame.
:73’s de Edd
::The #47 tube (audio driver) in my Philco 70 gives off a blue light on one side. I tested it for gas on my Hickok 534 and it was negative. I put in a NOS 47, and it also had a tiny tinch of blue on one side (it also tested negative for gas). I recapped everything except the tiny value molded caps. The resistors tested within tolerance. Is the blue glow to be expected, or should I look for a problem that doesn't involve caps or resistors???
::As always, thanks in advance for your help!
::Jeff S.
Also, a gassy tube usually glows purple.
Thanks for the information. It is as you all described. I turned up the volume and turned down the lights; there is some pulsating in the glow that's neat to watch. I'm considering building a remote socket for the 47 so I can set it beside my P-70 and watch it do its thing.
Jeff S.
