Anyway, your new potentiometer should be a 3K unit. Your old one probably has a crack in the carbon element. Disassemble it. If you need help with this, send me a photograph of the control. Carefully mend the crack in the carbon element with rear window defogger patching material (found at an automotive parts store). If you are not able to do this, simply replace the control. Since the control is likely linked to the on-off switch, it would be ideal to restore the original control, especially for authenticity.
:M = 1000 in Roman numerals.
