Signal generator
2/28/2006 9:04:29 AMMark S
I have my signal generator ( 2 prong plug) plugged into a power strip,
I have my isolation transformer ( 3 prong plug) plugged into the same
power strip, I have my radio ( 2 prong plug) plugged into the isolation
transformer. I have the black lead, from the signal generator clipped to
the chassis of the radio. Do I need a wire from the radio chassis to the
third receptical hole (ground) on the power strip?
2/28/2006 11:04:56 AMThomas Dermody
Nope.
2/28/2006 11:06:53 AMThomas Dermody
You can if you want. This will protect you from any capacitive coupling through the transformer--you can always get a zing on AC sets even though the chassis isn't connected directly to the line (though this can also be due to a chassis to line cord condenser). If the generator doesn't have a connection to ground, then a connection from the radio chassis to ground may prove helpful. Make sure that the generator is transformer operated (most are).
