Philco 40-180 dial lamp
2/27/2006 8:55:04 PMMike
I just completed re-caping and aligning my 40-180 console. Plays just great! Can anyone tell me the dial lamp bulb number? Can't find it in the literature.
2/28/2006 10:16:19 AMDoug Criner
Schematic: http://www.nostalgiaair.org/PagesByModel/336/M0013336.pdf
Strangely, the schematic doesn't show how the lamp is wired into the chassis. So, measure the voltage across the lamp socket. Probably 6V or so?
Is the lamp a screw-type or bayonet? Pick one out from the lamp data sheet here under "References."
Often, there will be two lamps with the same voltage rating and base, but with different amp ratings - e.g., a #40 and a #46. The one with a higher amperage will run brighter and hotter.
2/28/2006 1:23:16 PMMike Winney
:Schematic: http://www.nostalgiaair.org/PagesByModel/336/M0013336.pdf
:Strangely, the schematic doesn't show how the lamp is wired into the chassis. So, measure the voltage across the lamp socket. Probably 6V or so?
:Is the lamp a screw-type or bayonet? Pick one out from the lamp data sheet here under "References."
:Often, there will be two lamps with the same voltage rating and base, but with different amp ratings - e.g., a #40 and a #46. The one with a higher amperage will run brighter and hotter.
Thanks Doug & David for your replies. Found info on the great Philco Repair Bench web site. Bulb Type F, 6-8v, 200ma., bayonet. May be replaced with Type 44.
2/28/2006 10:51:19 AMDavid
Try philco radio.com
