I'd like to get a road map before I start
so I know what all them thingy ma-bobs are for..
It has 6 large brass cylinders next to the tubes.
never seen any thing like it before. I pick up
a few 1950's radios now and then , I can make
them play for the most part and can find tubes
and caps my local junk store they stock 30,000+
tubes and tons of N.O.S...
If you ever need a Tube give me the # and I'll
check his stock pile.
Ron , Weatherford, Texas
I can't recall encountering a 9-tube AC-powered TRF. Seems a little unusual.
A very common tube line-up would be: three '26s as RF amps, a '27 dectector, a '26 first audio, one 171A second audio, and the '80 rectifier. You've got one additional '71A and one more '26, which is interesting.
Between each RF stage, including the detector, there should be an RF coil. These are usually OK. Between the detector and each audio stage, there should be an audio interstage xfmr. These are often bad.
Unless you have some TRF experience, getting this thing running without a schematic might be a chore. I wouldn't think of trying to troubleshoot it without a speaker attached because: a) your B+ voltages will be thrown off, and b) you can't tell whether it's working, or the symptoms if it isn't working.
You don't need a horn speaker. Any vintage high-impedance speaker will be OK, like an RCA 100A, Atwater-Kent E series, or even with a modern PM speaker and an audio xfmr.
:Tubes..
:(5)UX226 (1) UY227 (2)UX171A (1) #80
:It dose take a Horn, I will find one later..
The extra '71-A is used in the audio output stage. This set has a balanced (push-pull) output for better fidelity, less hum and distortion, and higher power output. The extra '26 is probably an "antenna coupler" stage. A longwire antenna affects the tuning of the first rf stage, and the use of an extra tube, set up with a resistance coupled input (from the antenna and ground circuit) with a low gain (approaching unity, in fact) isolates the tuned circuits from any antenna capacity or inductance effects, and insures that the tuning system "tracks" properly over the entire dial.
Can you explain the five copper cans that Mike describes? I'm sure they wouldn't have been filter caps, and the number of RF/AF xfmrs doesn't seem to match your circuit explanation.
I'm unfamiliar with Airlines from this era. In later years, I've found Airline sets (Montgomery Ward) to be somewhat higher quality than Silvertones (Sears, Roebuck).
