6K7 IF Amp. Cathode should be 3.2V. I have 7.2V. Screen grid should be 50V. I have 76.4V. Plate should be 275V. I have 241.5V.
6J7 Det. Cathode should be 2.3V. I have 4.0V. Screen grid should be 50V. I have 76.3V. Plate should be ?? I have 209.7V.
6F6 Output. Cathode should be 18V. I have 10.8V. Screen grid should be 275V. I have 241.2V. Plate should be 260V. I have 3.8V.
Although all of the tubes tested good, could there be a problem with the output tube?
Help!!
However, before I mount and permanently wire in a substitute transformer, I need to know how to determine the electrical requirements for this set? The schematic only has the resistance values for the primary and secondary windings. When looking for a substitute what do I look for? Is this circuit hard on output transformers?
:The plate voltage on the output tube is too low. Your most likely suspect is the output transformer T2. Its' resistance should measure about 650 ohms. It may be open. Also check the capcitors C27 and C28 as either one may be shorted but you recapped the set so they should be fine. Check for any miswires that were done while recapping or by any previous repair attempts (technician tracks).
:MRO
Sorry to get so technical, but this is the dilema we must face when replacing transformers. Just about any tube type transformer will do in your radio, as it's pretty flexible. To get optimum audio quality and strength, purchase a universal output transformer from www.tubesandmore.com, or radiodaze.com. It will have a tapped primary and secondary. Your speaker is most likely a 3.2 (or 3.5) ohm speaker, as this was common, but since it probably isn't marked, you'll have to try different taps. First connect the primary tap to the output tube plate that puts the appropriate voltage on the plate. Several may give a similar voltage. Then choose the secondary that yields the best and strongest tonal quality. Now do the same with the primary. Hopefully your plate voltage will remain the same for optimum output. It can increase, but this will load down the power supply more. You'll get more wattage, though.
Keep in mind that decreasing the primary's impedance will decrease bass response but increase wattage. Increasing impedance will decrease bass response but decrease wattage.
Touch the center terminal of the volume control pot with a screw driver or your finger, and see if you get a hum. If so, the audio section is likely functioning.
Check the IF xfmr secondaries for continuity. (You've got B+ everywhere, so it seems that the primaries are OK.)
Put another radio next to the A53. Tune the other radio to a quiet point on the dial around 1360Hz. Then tune the A53 back and forth around 1360-460 = 900Hz. See if you can pick up the A53's oscillator whistle on the other radio.
