Now, my problem with this supply, which I had even before I devised the slow start feature, is that each of the regulators is rated to pass 1.5 amperes at up to 35 volts. The supply is supplied through a full wave rectifier, and is supplied from a 1.5 ampere 12 volt transformer. Adequate filtering is provided by me both before and after the regulator. I use two 3300 MFD units both before and after the regulator, so the DC should be fairly smooth. With 6 201A tubes, exactly 1.5 amperes is being drawn. However, when using only one regulator, the regulator gets incredibly hot and shuts off due to the internal thermal protection which is built into the unit. I then wired three of them in parallel. They can run longer, but soon shut down due to thermal overload. There is mention in the literature on the back of each regulator package of the need for heat sinking. I put heat sinks on all of them, and now they can run indefinitely, but they still get incredibly hot. They smell like a computer after it's been on for a while. Now I'm passing the recommended amount through them, and with 3 in parallel, I'd think that they could handle this, as each is rated for 1.5 amperes, and I'm passing 1.5 amperes through 3 of them in parallel. Is this okay? I think that such hot temperatures with solid state circuitry would be detrimental to longevity. If any of you solid state guys have answers to this, I'd be glad to know them. Otherwise, if that's the way it's supposed to run, the slow start feature should make this one nice A battery eliminator for everyone, especially those with thoriated tungsten tubes. I would just hate to see one of those regulators short out and blow my tubes, though.
Regulator case style: TO-3 case style generally has a higher wattage rating than TO-220. If you can get TO-3 case style you would be better off.
Balancing resistors: When you put solid state components in parallel, they will not always draw equal current. Often one will hog most of the current. Use .1 ohm (that is right .1ohm) resistors on the output terminals.
Bypassing: Use tantalum capacitors as close to the input and output terminals on the regulator as possible. Even with brute force filtering these regulators can oscillate and they will fry tubes if the do.
Crowbar protection: Find a overvoltage protection circuit and use it. Better a toasted power supply than toasted 201a's.
LM-150,250,350: This a 3 amp version
Boost transistor: Consider using a boost transistor instead of extra regulators. Most data sheets show this configuration. I have made a 13.8 volt 25 amp power supply by using 5 boost transistor and one three terminal regulator. If you use a boost circuit mount the three terminal regulator on its' own heat sink so it will not drift because of the boost transistors heat.
Big heat sink: Bigger better. Use thermal grease even on metal to metal mounting arrangements.
This is not a difinitive list but I hope it helps.
MRO
http://www.moah.org/education/transHist1.html
Date 1923:
Westinghouse develops, and RCA manufactures, the WD-11, a tube with a lowered filament power of 0.25 amp at 1.1 volts, using the Wehnell oxice-coated filament. The UV199 "peanut" tubes followed, offering an even more efficient filament (0.06 amp at 3.3 volts), bringing about a great saving of battery power. This same-style filament was installed in the 201 tube, which was renamed the 201A and given a new lease on life as a result of the more efficient use of filament, or "A" battery power.
Regarding what Mark said, you're right about the regulators not being perfectly matched. I kind of figured that this would happen. It starts out that one gets really hot and another gets less hot. The third is only warm. Then, as things progress, they all get pretty hot, but the initially warm one doesn't get as hot as the rest. I'll have to come up with a different circuit. Using high power transistors and zener diodes sounds best instead of relying on poorly manufactured/rated regulators. I do use grease between the regulators and the heat sinks. I have noticed that the transistors in the voltage regulator which I built for the generator in my car do not get that hot. They are high current type transistors (I forgot the exact type). The field coil draws 2 amperes. When the battery is low for any reason, the transistors are feeding the field coil constantly until the time comes for them to taper off the voltage. I've been using this regulator for 2 years now with no troubles, and again, the transistors don't get that hot.
....So, it seems like you both have some very good ideas for me to experiment with. I wonder how many circuit boards I will go through before I get the right circuit. Right now I have my A battery eliminator powering a simple #44 bulb, and one of the regulators is still getting hot. What pieces of crap! None of them get hot when the supply is unloaded, so there definitely isn't a short in the supply.
BTW...
Here's a cheap great thermistor.
for only about $1.42
It starts out at 220 ohms when cold the reduces itself to a few ohms as the current thru it warms it up slowly... 5 - 15 seconds or so I think.
It can handle 2 amps.
I bought 10 and use them in tube sets with tubes I am afraid to loose.
http://newarkinone.com/
SL15 22102
AMETHERM NTC Thermistor Resistance:220Ohm; Thermistor Tolerance:+/- 25%; Steady State Current:2A; Dissipation Constant:18mW/C; Leaded Process Compatible:Yes; RoHS Compliant:Yes; Mounting Type:Through Hole; Terminal Type:Radial Leaded
The capacitor does affect load regulation. It is not out of the circuit when charged. It acts like a battery attached to the adj terminal. When the load suddenly increases, the output of the regulator drops a little bit, the adj input doesn't see this drop for a long time because the big cap has to discharge before the drop appears at the adj terminal.
For this application it is probably OK, but a rapidly changing load would present a problem.
:Wow, you guys both are a help. Regarding what Peter said, the capacitor doesn't seem to affect voltage regulation. When it charges up, it basically puts no load on the circuit, so it's out of the circuit. It has no more resistance, so to speak, than the resistor which it is in parallel with. It actually never has resistance, but the initial charge up acts as though the variable resistor was reduced in resistance and then gradually brought up, which allows the regulator to increase voltage. Once the capacitor is charged, I can remove tubes and put them in, and turn on toasters, and everything, and the voltage remains at exactly 6 volts at the output of the regulator. I can even short out the regulator momentarily, and then the voltage jumps right back up to 6 volts. I'd have to draw you a circuit of the regulator to show why this is so, but it's pretty conventional, so I bet you can picture it.
:Regarding what Mark said, you're right about the regulators not being perfectly matched. I kind of figured that this would happen. It starts out that one gets really hot and another gets less hot. The third is only warm. Then, as things progress, they all get pretty hot, but the initially warm one doesn't get as hot as the rest. I'll have to come up with a different circuit. Using high power transistors and zener diodes sounds best instead of relying on poorly manufactured/rated regulators. I do use grease between the regulators and the heat sinks. I have noticed that the transistors in the voltage regulator which I built for the generator in my car do not get that hot. They are high current type transistors (I forgot the exact type). The field coil draws 2 amperes. When the battery is low for any reason, the transistors are feeding the field coil constantly until the time comes for them to taper off the voltage. I've been using this regulator for 2 years now with no troubles, and again, the transistors don't get that hot.
:....So, it seems like you both have some very good ideas for me to experiment with. I wonder how many circuit boards I will go through before I get the right circuit. Right now I have my A battery eliminator powering a simple #44 bulb, and one of the regulators is still getting hot. What pieces of crap! None of them get hot when the supply is unloaded, so there definitely isn't a short in the supply.
:Thomas
Mark,
You are "right on." Paralleling regulators is always a problem. Unlikely they will share equally. Much better to use an external transistor driven by one regulator. All the regulator data sheets show circuits for this hook-up. My favorite is an LM317 driving a 2N3055. Reducing the raw input voltage would help a lot. You don't need 16 volts coming into the regulator. 5 Volts would be more than adequate. The regulator must dissipate any excess voltage as heat.
TO-220 cases will handle only a watt or so without a heatsink. Even with a good heatsink, I wouldn't push more than 10 Watts. Also, 3300 mfd. caps maybe a bit too low. Use some tantalum in parallel with the electrolytics. Tantalum has lower internal impedance and will prevent oscillation.
The slow start circuit is interesting, but probably not vital. It will reduce the response time for the regulator to compensate for line or load voltage fluctuation, but that's probably not a major issue.
Regards,
Rich
(formerly applications engineering mgr. at Siliconix)
As far as the soft-start feature, I personally do not think this is a very necessary feature. Just switching on the battery eliminator should provide a softer start than switching a 6-V battery across the "A" supply, which is how the set was originally operated.
Further, the three RF filaments are attenuated by the volume control, which will seldom be full-blast at startup and the detector's filament voltage is permanently dropped. Yes, the two audio tube filaments run at full voltage.
I've found '01As to be quite rugged and long-lived. I've rejuvenated weak '01As by running their filaments at 6.3V or even 7.5V for hours on end - and I've never had a filament blow during the exercise.
For your C- supply, I'd consider a 3.7-V lithium battery.
Regarding why I chose 12 volts as my input voltage as opposed to 6.3, which could be possible if I make use of the transformer's center tap and a more traditional full wave rectifier (two diode) circuit, is because I felt that filtering would be better if I started with a higher voltage. This would allow the regulator to pass only what it needed. The electrolytics on the primary side could then charge up fully, or at least above 6 volts, which would reduce hum. Perhaps I am wrong on this? With choke filtering it is usually desirable to have a much higher voltage than necessary prior to the choke. If you all feel that my regulator will run cooler, and without hum, if I feed it with 6.3 volts AC instead of 12.6 volts AC (rectified and then filtered), I will change the circuit to suit this.
Rich
:Tis alright. I also rewired the regulator so that it controlled a transistor. I forgot the exact number of the transistor, but it ended with 3055. This transistor is supposed to be able to handle 10 amperes. It gets incredibly hot, though. I think I miswired the sensing circuit or something, as the voltage is stable with input voltage changes, but is not stable with output load variations. Perhaps a rewire would cure both problems. I don't know. I'm going to have to give this some thought. Another thought was to use 3 regulators again, and have a separate adjustment for each, and then adjust each on its own so that they all conduct exactly the same. This way they'll be fairly balanced. Whether or not they'll stay balanced is another thing to think about. AES's kit sounds nice now, even though it costs a bit more.
:Thomas
