Anyhow.... about 10 hours later I have this thing working. All recapped, new wiring where needed etc. Here is my issue though...
I seem to only have 2 degrees of volume with this one, none and full. I have treated the control with contact cleaner and still no help. No matter where I set the control I only get maximum volume.
I was working blind on this one since I could not find a schematic. The schemation on this site for a 41-220 must be wrong because it is only one page and is for a phonograph.
Can anyone direct me on where to start looking to figure this out. I assume it may be as easy as a bad volume pot but that just seems to obvious to me....
Take your control out and measure across the end terminals, and also make sure that the low terminal (shaft facing you, terminals facing down, this would be the left terminal) is connected to wherever it's supposed to be connected to.
For now I have one I grabbed from a junker I had but the shaft is way to long and not correct for the knob.
Where can I get a replacement? It is 500K 1-3/8 half rounded shaft. I checked AES and Radio Daze but they only have the ones that are completely round
Chris
:Sounds almost like the pot is broken at the low end. Since you are able to turn the sound off, this indicates a broken element, causing the volume to be gone at the low end, but then it jumps up to full. Changing position may slightly increase treble. Normally a volume control has one side of the element connected to the signal source and the other connected to the chassis or some other similar point (which happens to be out of phase with the signal source). As you turn down the volume, the signal is sent through more and more resistance, the connection to the chassis reduces in resistance at the same time, shunting out the signal. The combination of the two achieve optimum tonal quality and volume control.
:Take your control out and measure across the end terminals, and also make sure that the low terminal (shaft facing you, terminals facing down, this would be the left terminal) is connected to wherever it's supposed to be connected to.
:Thomas
But I do it differently for generally quick fixes.
It's kinda hard to find pots with the exact shaft length or type anymore. So I keep some in my 'stash' that I can "make" into what I need without too much hassel.
The pots from AES are great. I buy the 500k with a switch... Cheap.
And the shaft length I order from them is 1-1/2".
That shaft is round... but because it's aluminum it is easy to cut to length if I need it shorter and easy to file a flat side on it as well.
I also buy from Kelvin.com
They have 500k pots w/switch too... but the shaft is only about 3/4" long and knurled with a split in the middle. But these are very easy to solder to.
So just yesterday I needed a longer knurled shaft. So I hack-sawed off the needed length from the old pot's brass shaft and soldered it right onto the end of the short shaft of the new pot.
I just lay the ends next to each other holding the short end on the very end with a vise-grip. Heat up the joint where they meet... flow solder in there and position the two shafts so they align straight.... A little fiddling.. but great success.
Kelvin's part number is:
Code: 110029
Price: $1.50
Regarding soldering two shafts together, for a little extra strength, saw a slot in one shaft and file the mating shaft so that it has a "key" to fit into the slot. Solder. This may make the joint a little stronger if you experience breakage with butt-end soldering. If you aren't brutal with your controls, though, simply butt-end soldering them should work wonders.
As far as soldering the shaft ends.. it's so solid you wouldn't believe it! The solder even flow-ed (flew?)lol... right down the groove a ways too.
CMcKenna,
May want to check out Philco 41-225 on this site.
