Rich
:Hi
: I have an older Television Set that does not have a Coax input connector, and want to connect a Cable ready VCR to this unit, I'm quite sure it involves more than just connecting a Balun between the two, my question is what would I need and next where would I get one of these things to do this?
:Mark
Rich
The input to the tuner is 300 ohms. If you can move the balun transformer to a location right at the tuner input, then you can run 75 ohm coaxial cable from the tuner to the back cover of the TV. Drill a hole in the fiberboard back and mount an F-type cable chassis connector. I think you can get them at Radio Shack. You may have to ground the outside shield of the 75 ohm cable to the TV chassis to eliminate the interference. It' worth a try unless you are reluctant to drill hole in the TV back panel. Rich
There are variations in 300 to 75 ohm transformer converters. If your transformer (balun) is not of the highest quality, and doesn't pass all signals well, this may affect the clarity of your picture, though in black and white this may not be evident. A lot of interference you see on a color television won't show up on a B&W because it affects the color signal only. Also, cables with a wide separation between the center conductor and the shielding have less capacitance between the two, and pass high frequencies better--clearer picture. These are just things to think about.
Hi Mark,
How many channels off the cable do you get?
Bill
:::::::: I have an older Television Set that does not have a Coax input connector, and want to connect a Cable ready VCR to this unit, I'm quite sure it involves more than just connecting a Balun between the two, my question is what would I need and next where would I get one of these things to do this?
::::::::Mark
::::::::Hi Rich
:::::: Well I've tried it with just a simple Balun, I get the channels, but not without alot of interference, by the way this is a very old TV, its a 1948 Zenith with only a Twin lead VHF input terminal, if that makes any difference.
::::::Mark
:::::You are probably getting pick-up of local channels via the length of twin-lead that runs from the Antenna terminals back to the tuner box. I suppose you could try shielding this portion with some aluminum foil, but that may not work.
:::::Rich
:::::Hi Rich
:::: Yep, thats what I'm thinking too, wish there was a way to convert this 300 Ohm Twin Lead input on the set too a 75 Ohm Input, that would probably solve the problem, thing is I have no idea how too do this.
::::Mark
:::The input to the tuner is 300 ohms. If you can move the balun transformer to a location right at the tuner input, then you can run 75 ohm coaxial cable from the tuner to the back cover of the TV. Drill a hole in the fiberboard back and mount an F-type cable chassis connector. I think you can get them at Radio Shack. You may have to ground the outside shield of the 75 ohm cable to the TV chassis to eliminate the interference. It' worth a try unless you are reluctant to drill hole in the TV back panel. Rich
::Hi Rich
:: Well I solved the problem, the contacts on the tuner for CH4 were extremely dirty, I cleaned all of them then retuned CH4 with VCR hooked up and alakazam I now have a pretty good picture on all of the cable channels, considering I have a fairly long run of cable to feed it, looks nice:). As too grounding the Shield on the cable, no can do, on this chassis the top portion of it is run hot, and I'm not much for sparks flying everywhere LOL, thanks for your help on this, by the way you were right a simple Balun works, probably not as good as a direct 75 Ohm coax would, but at least its a half way decent picture and thats what counts:)
::Mark
:Hi Mark,
:How many channels off the cable do you get?
:Bill
