Atwater Kent speaker plug.
2/9/2006 5:33:52 PMJon(36778:0)
Hello all,
I am finishing up an Atwater Kent model 717 tombstone that is missing the speaker plug. A standard 4 pin tube base will not work as the pins are too far apart. Anyone have a solution for a replacement?
Many thanks,
Jon
2/9/2006 5:47:43 PMRadiodoc(36780:36778)
:Hello all,
:I am finishing up an Atwater Kent model 717 tombstone that is missing the speaker plug. A standard 4 pin tube base will not work as the pins are too far apart. Anyone have a solution for a replacement?
:Many thanks,
:Jon
Jon,
One place you may want to check is http://www.radiodaze.com. They have several different types of plugs.
2/9/2006 7:01:54 PMDan Livesay(36784:36778)
:Hello all,
:Many thanks,
:J
Hi Jon: For a temporary solution you can solder individual pins on the speaker leads and plug each wire in seperately.You can use the pins from a bad order four pin tube
