Try another 6BE6. Since you have two in this radio could reverse positions? A 6BE6 oscillator can test good and still not operate properly on FM.
:I have an RCA AM/FM Set 68R3 (Chassis RC608) (Rider's Vol 16; Pages RCA 16-39 - 16-42). I have recapped it and replaced the out of tolerance resistors and it plays beautifully on AM. On FM it catches the band from about 102-108 across the first 20% of the dial, then nothing. I took a shot at the alignment procedure from Rider's with no improvement (I have an Eico 315 Sig Gen that goes up to 150Mhz). I've tested all of the tubes-ok. Anybody got any ideas?
:Thanks, Jim
Joe
:Hi Jim
: Try another 6BE6. Since you have two in this radio could reverse positions? A 6BE6 oscillator can test good and still not operate properly on FM.
::I have an RCA AM/FM Set 68R3 (Chassis RC608) (Rider's Vol 16; Pages RCA 16-39 - 16-42). I have recapped it and replaced the out of tolerance resistors and it plays beautifully on AM. On FM it catches the band from about 102-108 across the first 20% of the dial, then nothing. I took a shot at the alignment procedure from Rider's with no improvement (I have an Eico 315 Sig Gen that goes up to 150Mhz). I've tested all of the tubes-ok. Anybody got any ideas?
::Thanks, Jim
It looks like the 106 Osc trimmer (C33 2.5-13mmf) isn't changing value when it is adjusted. I'm going to see if I can find one to replace it with.
