Please Help: Need dial cord diagram for Korting (Delmonico) Model 1047.
2/11/2000 1:30:02 PMDave Froehlich
Hello All,
This is a very frustration situation. The FM dial cord Popped-off and I cannot figure out how it goes on. A Pulley also popped-off at the same time. I'm not sure I put it back in the right place. I wonder why they make these things so elaborite?
Each time I get the dial cord on one pulley, it pops-off another (I think we've all been there before). But with a diagram I should have no problem, I hope. Please help. I have old RCA schematics to trade.
The Korting set was made in Western Germany and there is a Sam's Photofact for it. It looks like a 60s set.
Thanks again,
Dave...
4/3/2000 11:02:57 PMRich Kalynchuk
I own a Korting Delmonico. I do not own a manual. Let me know if I can help. Write or call 216-398-5189. I am not an electronics wizard but I would like to hear from you. I could use some advice on what it is that I own.
: Hello All,
: This is a very frustration situation. The FM dial cord Popped-off and I cannot figure out how it goes on. A Pulley also popped-off at the same time. I'm not sure I put it back in the right place. I wonder why they make these things so elaborite?
: Each time I get the dial cord on one pulley, it pops-off another (I think we've all been there before). But with a diagram I should have no problem, I hope. Please help. I have old RCA schematics to trade.
: The Korting set was made in Western Germany and there is a Sam's Photofact for it. It looks like a 60s set.
: Thanks again,
: Dave...
3/19/2003 6:54:29 PMDave K.
Hello!
I also have one of these 1047's - I have searched for a dial stringup diagram EVERYWHERE on the Web, here and abroad - I even try to get any seller on EBay who has one up for auction to tell me what the stringup is, to no avail - no one wants to open one up! I've even purchased schematics from two different sources, but the FM dial stringup is not there!
Has anyone found out this information on this forum?
Please send any info to me at my address - thanks!
:Hello All,
:Each time I get the dial cord on one pulley, it pops-off another (I think we've all been there before). But with a diagram I should have no problem, I hope. Please help. I have old RCA schematics to trade.
:The Korting set was made in Western Germany and there is a Sam's Photofact for it. It looks like a 60s set.
:Thanks again,
:Dave...
3/21/2003 3:28:21 PMRolf Zetterberg
I doubt if you could find a dialstring diagram on a Körting schematic,since none of my 44 Körting schematics has.On the other hand I could open my Körting Novum 3940(late 50's)and have a look,if somebody is interested.
Rolf
living in Sweden
3/21/2003 8:37:47 PMJohn McPherson
I doubt if you will find a stringing diagram, and Iam not sure if a different model would be close enough, other than to get an idea of how they were thinking at the factory.
I know how daunting it can be, but sometimes you need to invest in a spool of braided fishing line, and start from the first loop.
I know it is easy to say it- Just try it- But usually with a little patience and logic, you can figure out how you need to string it in order to work. (the spring on the end allows for imperfect distance judgement when you cut the string. I sepak from experience that restringing is not as bad as it sounds, and in actual fact, there are times when the original plan does not work as well as what you can end up with.
:I doubt if you could find a dialstring diagram on a Körting schematic,since none of my 44 Körting schematics has.On the other hand I could open my Körting Novum 3940(late 50's)and have a look,if somebody is interested.
:Rolf
:living in Sweden
