Cartridges are seldom listed under the name of the turntable/changer manufacturer.
This guy might be able to help you: http://www.jukn55.com/
Doug , Its an interesting type of device I guess . I got the description from the "resources " on this site .I am not sure how much of that description is technically accurate.I get the feeling you are right that a standard cartridge might not work .I will compare this circuit to one that runs a magnetic or ceramic just to see if there is any similarity .Other than that I will follow your link.If a common cartridge will go in there I would be all set.Like you said the cartridge manufacturer is most likely not Admiral.Without a cartridge I only have the Admiral part number.But least I have some direction to dig in and a link to check out.Maybe some one out there has one of these sets .It is a 7RT41-N with a RC170A record changer. Thanks for the help !
