Enamel wire can withstand a higher temperature, and has been used since the year one. If you are able to heat it high enough, it usually makes a dirty solder joint that I do not recommend. Even a potable coating can sometimes leave some black in a joint that is heated with a dirty tip due to excessive heat. However, I am most likely to use that method with a potable coating, even though I don’t always like it.
Enameled wire was still available a few short years ago, but I haven’t tried to buy any recently, so can’t say about today. Of coarse, this wire is not supposed to be potable, and the ease of stripping depends on whether it is single enamel, double enamel, or triple enamel. As Peter suggested, emery cloth works pretty good, especially on wire sizes in the range of #30 (.01) or #31 (.0089) with triple enamel. For stripping enamel on small wire above #36 (.005), I prefer using a small folded piece of 600 grit wet or dry sandpaper. Second choice is #0000 steel wool, but it is pretty tough on #40 (.0031) or #42 (.0025”) wire. Thankfully I have used up most of the old enamel wire in these small sizes, and use modern wire for rewinding audio transformers and speaker fields....br
I failed to mention that the wire diameters used in my previous post are for bare copper, not coated wire....br
Rich
:Well shucks, I hit the wrong button.
:I failed to mention that the wire diameters used in my previous post are for bare copper, not coated wire....br
